Search Results (Searched for: gs swing arm)
Greetings from Scotland was created by Alrsv1
13 Sep 2025 09:21
Hi all, thanks for the add.
Picked up this 1984 GPZ750 A2 recently (not my first, had a couple of others in my time) which is in prettty good shape for a 41 year old UK bike.
Got 42k miles and been well looked after, came with loads of receips and spares including the origial exhaust which I'm going to put back on.
So far I've checked the compression (all good), balanced the carbs, installed a Hagon shock and replaced/cleaned the swing arm and linkage bearing, and installed an APE
CCT which definitely helped quieten down the rattle.
Looking to improve the riding position as it's a bit streched and low for me so have ordered a pair of the taller handlebars from a 750 Turbo as they look like they should go straight on
but of course it wont be that simple, it never is.
Cheers for now...
Al.
Cheers for now...
Al.
Replied by Wolfhound on topic Greetings from Idaho!
01 Sep 2025 13:09
Here is a current Pic. I'll have to look for some of the older pics during the unpacking at the new digs.
pretty much everything is painted body color, polished or chromed. I settled on the ZR550 wheels to keep the same theme of painted wheels with polished rims and side of the spokes. I'm thinking the ZRX swing arm will get polished.
I burned a valve while I was in Monterey for WSBK in 96. I swapped the head with my Kz700 Parts bike and installed new rings. It started ticking when I fired it up. I d
idn't have the time/money/place to deal with it at the time.
I had purchased a beater 82gpz to ride in the mean time so it eventually donated its heart. Then in 01 it started leaking oil from the cooler lines and had a couple electrical issues. My better half convinced me to buy something new and reliable, so I ended up with the 01 speed triple and loved the reliability and performance improvements.
When I fired up the L3 in 2000 it smoked like hell. It sat too long and I think the oil rings are stuck.
I'm thinking its time to go through the original motor and put it back in.
Attachment not found
Back in the USA this month for Docrot's awesome 750 twin, over to Doc
Origin StoryI originally picked this bike up for a friend for $300. I was helping him get it back on the road and he ran out of money and interest so I bought the project from him. I wanted to do all the same things that guys were doing to the Z1/KZ1000 with a focus on improving the chassis and handling while reducing weight. It's been through a few iterations over the years to really dial in the ride experience - I can't stand a bike that doesn't function well. I rode this bike to my college graduation and was doing wheelies and burnouts on it in my graduation robe. I have had it on several road trips and a few years ago sold it to a good friend with whom I regularly ride with.
Chassis & GeometryFirst up: geometry. I cut off part of the subframe and moved the shock mounts forward to improve progressive movement through the swingarm’s arc. The motor mounts were fabricated in aluminum plate, the engine cases were reamed to accept oversized bolts—eliminating factory slop and tying the chassis together more rigidly. A custom pair of Works Performance shocks were installed, and I raised the rear ride height to improve rake and trail while also adding cornering clearance. A hand-fabricated aluminum swingarm beefs up the rear end, finished off with a hollow chromoly axle.
Front End & SuspensionTo retain a factory-like appearance and ride height, I stayed within the KZ lineup. The front forks are from a KZ1000, now running Race Tech cartridge emulators and a custom chromoly axle. The heavy cast wheels were replaced with spoked units from a KZ650, dropping unsprung weight. The front brake setup includes a lightweight EBC disc paired with a Brembo caliper on a custom mount and master cylinder. A Tarozzi fork brace ties it all together.
Bodywork & VisualsThe KZ750 twin isn’t exactly a looker out of the box—it’s bulky and awkward. I wanted a design that felt cohesive, like something Kawasaki might have built as a special edition. The bodywork is a mix-and-match of KZ parts, chosen for visual balance and consistency. Stamped fenders maintain an OEM vibe, and I went the extra mile with details like early-style engine covers and a designed and cast an aluminum ignition cover featuring the classic Kawasaki flag logo.Up front, the headlight houses a GPS tach from Speedhut, and out back, I fabricated a custom tail light shroud. The handlebars were swapped for Fat Bars mounted with custom clamps that preserve an OEM feel. I relocated the ignition switch and integrated the oil light into the stem bolt to clean up the dash.
Paint & Finishing TouchesThe paint needed to feel period-correct—something that could’ve been on a showroom floor. After agonizing over color swatches, I landed on Jeep’s “Commando Green,” but added extra green toner to bring it closer to Kawasaki’s palette. The badges are from the JDM Kawasaki “Z2,” which felt like a fitting nod. The seat was done by JP Custom Seats in Los Angeles, whose craftsmanship really helped pull everything together.
Engine WorkThe current engine iteration is fairly stock but warmed over. The top end was stripped down and rebuilt with 1mm over pistons. Compression was bumped up, and the head received a light port and polish. It now breathes through a set of RS34 flat slides from Topham Germany and exhales through a custom-fabricated stainless steel exhaust. The real game-changer was the optical multi-spark ignition from C5. From the factory, timing was overly conservative—now corrected, throttle response is crisp and immediate.
The RideThe result is a refined version of the original—lighter, faster, and far more composed in corners. It feels like something Kawasaki could have built if the accountants weren’t in the room. Every rider who throws a leg over it is surprised by how fun and agile it is. I’ve ridden everything from cruisers to sport bikes to dirt bikes, but the way this thing tips into a corner is totally unique.
Greetings from Idaho! was created by Wolfhound
31 Aug 2025 22:35
Getting ready to start bring my L3 back to life after 24 years. I got it as the second owner after my 77 650 started giving me trouble. It was my daily driver until 96, when she took a break due to a burned valve. Swapped in an 82 GPZ motor 99, then was parked due to becoming unreliableI 2001 (when I got my Speedtriple).
We recently moved and when I had to trailer her to the new house I was inspired to get her back on the road.
I've been digging through the builds and other forums looking for inspiration.
A ZRX just donated a new swing arm and a set of ZR550 wheels are with the shipping companies.
I'm seriously thinking about the 6 speed gearbox upgrade.
Still need to decide what front end / brake upgrade to do. Would love to go with USD for the visual but that is still TBD.
If I get this one done in the next year, I may take on upgrading my GPZ basket case with a single sided swing arm and 1000/1100cc motor upgrade.
1982 KZ 1000 LTD - help me set a price was created by Pachyderm
25 Aug 2025 16:01
I need your assistance to set a reasonable price for this bike.
1982 Kawasaki KZ 1000 LTD, 20569 miles.
Here's the work I've done since August 2023
Stripped to bare frame and refinished components during reassembly
New front wheel bearings and seals, new fork seals, new rear wheel bearings and seals, new Shinko tires and tubes
Front calipers rebuilt, front brake master cylinder bored and relined with stainless steel, rebuilt
New throttle and choke cables, new mirrors
Tank petcock rebuilt, tank cleaned, new tank cap seal
All new engine gaskets and shaft seals, new valve stem seals, all valves lapped
New cam chain tensioner
New carb-to-head connectors, carbs rebuilt and vacuum balanced
Wiring harness inspected and rewrapped, all connectors depinned and cleaned
New front and rear sprockets
New Dynatek DS2-1 ignition pickup, timing confirmed by strobe light
New 2.6 ohm coils, wires, spark plug caps, and spark plugs (OEM IC ignitor bypassed)
New battery
New rear shocks, new swing arm pivot seals
Rear brake master cylinder rebuilt, Rear caliper rebuilt, new rear brake hose
Vance & Hines 4-into-1 header from previous owner
New seat cover, new electric horns, new handlebar grips
4 coats 2K (catalyzed) SprayMax clear coatGiven the scope of the project, I don't expect to break even. (Wrenching is my hobby, not a business.) Just want to explore a fair price.
What do you thinks, folks? What's a fair price?
Thanks for your help.
Todd
New battery
Todd
Bike is a 81 KZ55A2. Kid burned up the bearing on sprocket side. Nut was so tight the wheel almost wouldnt turn. Today i got new bearings and put them in. However when I tightened down the nut same thing happens. So i loosened the nut till the wheel would turn freely and started the bike. I noticed the spacer on the sprocket side that goes into the dust seal will turn on the axle and its not supposed to. Looking at the parts fiche I noticed theres an oring, part number 671B255 on the sprocket side. I didnt see any oring when i took off the wheel and pulled the axle. I laid everything out in order for reassembly and no oring.
So my questions are where exactly is this oring and does it fit next to the bearing?? And second is why is the spacer turning and why when i tighten the nut does it seize the wheel?
Only thing im unsure of is the spacer that fits inside the sprocket hub. Somethings definitely missing on the rear axle set up. Guess ill take it off the swing arm in the morning to check that everything i see on the fiche is there.
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
17 Aug 2025 15:55Replied by AOB85 on topic New Zephyr 750 owner
15 Aug 2025 22:20I don't know about that, the bike itself has 9k miles. I did order new bushings with the fork seals. I've thrown the parts cannon at this bike, now I am waiting for things to get here from Japan.Welcome from the UK, nice looking bike. If the fork bushes weren't replaced with the seals that may be why they still leak ?
Welcome.
Post up some more pictures after you ger her unloaded.
I've already got in unloaded and in pieces. Someone strapped down the rear grab handle so tight they cracked the frame where they mount.
The stock air box is properly fucked, stripped and broken bolt inserts. A block of wood was keeping it tight against the carbs. As much as I would love to keep it original I have ordered a factory pro pod jet kit, I have had good experience with his GSXR 1100 kit. The axle adjusters are facing the wrong way and the rear brake caliper banjo bolt has beaten the swingarm up pretty good. Missing the center stand for some reason. The gas tank cap is mangled from someone trying to pry it open even though the bike had a key. I'm sure I will find more problems when I start disassembling it to replace worn out things.
02 Aug 2025 23:02
Wellll...........
I have a 78 KZ 650 SR in the garage today, helping a friend with the Carbs, and other maint. after it has been sitting. This thing is so cherry, it even has the old break in procedure decal on the tach.
KZ's r the bestest.
Ted
KZ's r the bestest.
Ted
Replied by Wookie58 on topic Bike of the Month.
01 Aug 2025 00:22
Back in the UK this month for another from Warren's stable. A great example of finally having the means to get what you wanted but couldn't have "back in the day"
Originally bought unseen for £500 as a parts bike should I need anything for my all original green 650 B1 but everything on the green bike was sooooo much better condition than this bike. (pic1). So with a stash of parts that I had accumulated over the past 40+ years I decided to build the 650 I wanted in the 70's but didn't have the money or engineering confidence to do it back then. So first was a complete engine rebuild. Adding in piper cams, piper high compression pistons, skimmed head, cosmetic head gasket but still stock 652cc. Resulting in a compression of 220-230psi.Complete engine paint using simonez tough satin black. Stock vm24 carbs jetted to suit with stacks and tea strainer mesh filters. (pic2). Back in the 70's the exhaust of choice was a piper four into one but they rotted out pdq so finding one was next to impossible so I made a stainless replica and added a Moriwaki badge for bling. (pic3). Wheels are CMA race mags off a 900 at about half the weight of their road mags. Dresda box section swingarm. Forks are stock which have been altered to accommodate adjustable preload (pic4) and progresive springs. Ohlins on the back. Converted to twin discs which I surface ground and swopped the callipers to behind the forks with ebc red stuff pads with braided stainless hoses. (pic 5)Foot controls were originally period Raask but hated the levers so made some new ones to my liking. (pic 6/7) and added in a spacer to lower and move the footrests further back. Instruments couldn't stay standard but keeping with the period or home built parts only theme, the stock speedo stayed but the idiot lights changed to individual led's and a mini 2 inch rev counter all housed in a ally housing. Pic 7It's one of those bikes which is never really finished as it gets bits and pieces changed or built for it every winter. Then I found an issue with the rev counter drive ratio. When the engine was idling at 1000 rpm the rev counter read 1400 rpm. Apparently Kawasaki are the only ones that use a 7:1 drive ratio whereas the rest of the world use 5:1. That prompted the next little mod! Built a small inline reduction gearbox to correct the ratio issue. Pic 8&9Home made tail tidy, and tucked a smoked lens tail light in under the tail piece and built indicator into it. Pic 10. Relocated and changed the front indicators to a more tucked position and less obtrusive style. Homemade alloy chain guard, pic11. Renthals bars and black base with silver coach lines on all the body work. Pic 12.There's probably loads which I've forgotten to mention.
Displaying 11 - 20 out of 7254 results.
