1982 KZ 1000 LTD - help me set a price
- Pachyderm
25 Aug 2025 16:01
I need your assistance to set a reasonable price for this bike.
1982 Kawasaki KZ 1000 LTD, 20569 miles.
Here's the work I've done since August 2023
Stripped to bare frame and refinished components during reassembly
New front wheel bearings and seals, new fork seals, new rear wheel bearings and seals, new Shinko tires and tubes
Front calipers rebuilt, front brake master cylinder bored and relined with stainless steel, rebuilt
New throttle and choke cables, new mirrors
Tank petcock rebuilt, tank cleaned, new tank cap seal
All new engine gaskets and shaft seals, new valve stem seals, all valves lapped
New cam chain tensioner
New carb-to-head connectors, carbs rebuilt and vacuum balanced
Wiring harness inspected and rewrapped, all connectors depinned and cleaned
New front and rear sprockets
New Dynatek DS2-1 ignition pickup, timing confirmed by strobe light
New 2.6 ohm coils, wires, spark plug caps, and spark plugs (OEM IC ignitor bypassed)
New battery
New rear shocks, new swing arm pivot seals
Rear brake master cylinder rebuilt, Rear caliper rebuilt, new rear brake hose
Vance & Hines 4-into-1 header from previous owner
New seat cover, new electric horns, new handlebar grips
4 coats 2K (catalyzed) SprayMax clear coatGiven the scope of the project, I don't expect to break even. (Wrenching is my hobby, not a business.) Just want to explore a fair price.
What do you thinks, folks? What's a fair price?
Thanks for your help.
Todd
New battery
Todd
- Rryanflakz
