  • Page:
  • 1
1000j / 1100 rear cowl mount 02 Jul 2023 20:17 #886755
  • GPzed11
  • GPzed11's Avatar Topic Author
  • Thank you received: 12
Hi all, the metal mount on top of the tail light bracket that mounts the rubber damper for the ducktail / cowl;
is that piece available separate from the complete tailight bracket? I'm thinking it was spot welded on originally.
Pic shows mine, it was deleted when previous owner modified the main brackets to tuck the twilight into the cowl. He siliconed the cowl to the tallight lens for mounting. Worked okay I guess but I'm keen to get away from that and use a rubber damper.
Will probably have to have something made as the bracket has moved forward. if someone could post a detailed photo of the factory damper mount it would be much appreciated.
Gpz1100/1000J
Fraser Coast Qld Australia
1000j / 1100 rear cowl mount 02 Jul 2023 23:59 #886758
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 658
Google 23062-1032 plenty of pictures.
Might even find one to buy.
Z1000J2 somewhat modified!
The following user(s) said Thank You: GPzed11
Last edit: by Warren3200gt.
1000j / 1100 rear cowl mount 05 Jul 2023 08:16 #886864
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
Will this help?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
1000j / 1100 rear cowl mount 05 Jul 2023 13:19 #886881
  • GPzed11
Spot on, thank for the photos, that is the missing link.
Gpz1100/1000J
  • Page:
  • 1
