  • Page:
  • 1
Putting top coat over older primer 28 Jun 2023 07:03 #886561
  • Injected
  • Injected's Avatar Topic Author
  • Thank you received: 415
Need some advice before proceeding with top coat on a gas tank.
I have a tank that has had all the body work completed and its been sitting with primer on it for about a year.
The tank has been covered up protected from dust waiting to be finished.
Is it better to lay down a fresh coat of primer? (which I would need to purchase) or just directly spray the first coat of color?
Was wondering if there would be any adhesion advantage?
Putting top coat over older primer 28 Jun 2023 07:12 #886563
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2680
What type of primer?  If it's one-pack type, you can spray on top because the solvents in the color will bite in.  If it's two-pack, catalyzed primer, then a good scuffing with 600 grit, or gray scotchbrite, followed by a fresh layer of primer, is typically needed.  To know for sure, look up the data sheet for the primer material that was used.  If the paint has a critical recoat time, it should be highlighted in the data sheet.
Putting top coat over older primer 28 Jun 2023 07:36 #886565
  • Injected
Its just rattle can primer, Duplicolor sandable automotive series.
Just wanted to know if a extra coat of fresh primer would help the color coat adhere better.
Last edit: by Injected. Reason: sp
Putting top coat over older primer 30 Jun 2023 15:16 #886669
  • turboguzzi
  • turboguzzi's Avatar
  • Thank you received: 72
dont get offended, but I wouldnt even consider that primer as a proper base for bodywork, maybe for some gardening tools or a shed
get that thing off with thinners till you see metal again and spray some proper primer that has some zinc chromate or phosphoric acid content. at least itll have a chance to adhere to the metal.
my 2 cents of course..... ti's your tank after all
  • Page:
  • 1
