- Thank you received: 5
Rear brakes
- Maxbou92
19 Jun 2024 13:53 #900987
by Maxbou92
Kz750e 1980
Rear brakes was created by Maxbou92
Hello everyone, my rear brake are stucking when its really hot outside.. even if I don’t touch it !! Rebuilt the caliper, piston move like a new one. But when I bleed the system, it seems like it has always some air in the line?!! The Oem Hose are crimped with some “Plumber” collectors!! My oil level is always at full.. when the caliper stuck, I open the bleeder on it and Im ready to go again !!
thank you for your help
Kz750e 1980
- Moose1800
- Thank you received: 296
19 Jun 2024 14:10 - 19 Jun 2024 14:30 #900990
by Moose1800
Replied by Moose1800 on topic Rear brakes
Sounds like a collapsed brake line to me. When you open the bleeder your releasing the pressure that’s a tell tale sign of a collapsed line.
Last edit: 19 Jun 2024 14:30 by Moose1800.
- Maxbou92
19 Jun 2024 14:18 #900991
by Maxbou92
Kz750e 1980
Replied by Maxbou92 on topic Rear brakes
Does the air can cause that with the sun heat? A cold night will never collapse my brake .. so weird
Kz750e 1980
- Moose1800
19 Jun 2024 14:28 - 19 Jun 2024 14:44 #900992
by Moose1800
What do you mean plumbers collector, is it an old oem stock brake line?
Let’s see a picture.
Last edit: 19 Jun 2024 14:44 by Moose1800.
- Thank you received: 2070
19 Jun 2024 14:57 - 19 Jun 2024 15:00 #900995
by Scirocco
Replied by Scirocco on topic Rear brakes
Check the tiny relief port in the MC is not clogged.
Animation made by R.I.P loudhvx, AFIAK
MC normal movment
MC bleeding movement
MC normal movment
Last edit: 19 Jun 2024 15:00 by Scirocco.
- Maxbou92
19 Jun 2024 15:16 #900997
by Maxbou92
Kz750e 1980
Yes its my oem brake system!! Dont looks like new bike with Bolt to master cylinder!! Some clamp to the oil bottle and master cylinder!! Thank you for the picture. I will disassemble the master.. cannot find some pieces for rebuilt rear master cylinder
Kz750e 1980
- Thank you received: 2358
19 Jun 2024 15:26 #900998
by Wookie58
Replied by Wookie58 on topic Rear brakes
I agree with scirocco, I had a KH400 with same issue on the front (crack the nipple and good to go again) the return port in the master was blocked with crud.
- Maxbou92
- moizeau
- Thank you received: 13
20 Jun 2024 05:18 #901020
by moizeau
Replied by moizeau on topic Rear brakes
I'm another agree. Just had this on my ST on the front. After changing the top hose it wouldn't bleed and very small bubbles came out the feed hole. My suspicions were raised when it was impossible to back bleed. Once the hole was cleaned out it was bled in 5 minutes. I had initially put it down to a collapsing brake line or old fluid.
The following user(s) said Thank You: Maxbou92
