- Thank you received: 12
78 kz sr 650 rear caliper oops
- xstreamcanadian
18 Jun 2024 06:06 - 18 Jun 2024 06:06 #900921
by xstreamcanadian
78 kz sr 650 rear caliper oops was created by xstreamcanadian
So i got my bike all buttoned up, she fired up ran better than ever. Alrhough then i noticed a puddle. Brske fluid from the rear caliper pushing through the split of the two piece caliper(odd design to be sure)
Tore it apart and realized... i had forgotten the rubber washer that keeps it from doing just that. Part ordered, along with new pads as they were soaked too.... one ride one repair. She is living up to her name. This one was completely on me. Im looking for torque specs for this caliper, for the D1 if anyone has them. For the two allen hesded bolts that hold it together and also for the nut on the stabilizer bar. Thank you
Last edit: 18 Jun 2024 06:06 by xstreamcanadian.
- Thank you received: 2053
18 Jun 2024 20:14 - 18 Jun 2024 20:32 #900955
by Scirocco
Replied by Scirocco on topic 78 kz sr 650 rear caliper oops
Last edit: 18 Jun 2024 20:32 by Scirocco.
The following user(s) said Thank You: xstreamcanadian
- xstreamcanadian
20 Jun 2024 11:07 #901038
by xstreamcanadian
Replied by xstreamcanadian on topic 78 kz sr 650 rear caliper oops
Appreciate it. Yes I rebuilt the caliper and somehow missed the one o ring, or sealing ring they call it appropriately enough. Your photo shows two small o rings, but I have no idea where the bigger of the two goes. I ordered the o ring but couldnt find the torque specs so thank you so much for that sir
- Thank you received: 1918
21 Jun 2024 11:03 #901077
by Mikaw
Replied by Mikaw on topic 78 kz sr 650 rear caliper oops
I see the bigger oring as square, that would make them piston to caliper bore seals.
- xstreamcanadian
25 Jun 2024 11:26 #901309
by xstreamcanadian
I was talking about the photo, seems to have an extra o ring (small)
I received the sealing o ring and installed, along with fresh pads. Works amazing now and no leaks. whew....
