  • Page:
  • 1
1981 KZ1000 CSR mag wheel swap 25 Mar 2024 21:15 #896894
  • kzlaverda
  • kzlaverda's Avatar Topic Author
  • Thank you received: 0
Hello,
I recently purchased a 1981 Kawasaki kz1000 CSR with wire spoke wheels and rear disc brake and would like to swap to mag wheels.
I found an 18” rear wheel from 1981 Kawasaki kz1000J and was wondering if that would be a straight swap or will it need any modifications?
Any info would be greatly appreciated. Thank you
1981 KZ1000 CSR mag wheel swap 26 Mar 2024 05:52 #896897
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Maybe someone else knows for certain, but checking the diagrams at Partzilla, almost all of the part numbers are the same for the rear hub and brake.  Same: coupling assy (sprocket carrer), shock damper, axle, hub collar, chain, brake disk, and almost all of the brake caliper parts.  The only difference I found was the brake caliper assy has a different number, but that could be because of the brake pads (?) >> the J model has 2 different pads listed but one of them was used on the CSR. I'd say it would work. guessing.  ... ps: I don't know if the tire would rub the fender. I haven't done the circumference calculations.
www.partzilla.com/catalog/kawasaki/motorcycle/1981/kz1000-j1
www.partzilla.com/catalog/kawasaki/motor...e/1981/csr-kz1000-m1
Last edit: by martin_csr.
  • Page:
  • 1
