  • Page:
  • 1
Rear wheel change 13 Feb 2024 12:27 #895220
  • Bzmannn24
  • Bzmannn24's Avatar Topic Author
  • Thank you received: 0
I just recently bought a kz900 someone had changed to a 16” wheel.  If I go back to original 18” can I use the same brake hub assembly and back sprocket
Last edit: by Street Fighter LTD.
Rear wheel change 05 Mar 2024 20:40 #896023
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 258
Yes you can.  When I first got my Z1A the PO had changed the rear wheel to a 16".  I bought a used 18" wheel and everything fit .  He had also changed to the smaller front fender from an LTD, which I liked, so that stayed.
{apologies for the late reply !}
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: Bzmannn24
Rear wheel change 06 Mar 2024 10:50 #896046
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 86
Just buy a new 18 inch rim and new spokes and have it laced and trued. Maybe that was your intent.
The following user(s) said Thank You: slayer61, Wookie58, Bzmannn24
  • Page:
  • 1
