  • Page:
  • 1
Advice on upgrading wheels and brakes 16 Aug 2023 13:33 #888339
  • drunken_thor
  • drunken_thor's Avatar Topic Author
  • Thank you received: 1
Hey everyone, I have been slowly modernizing my KZ440 and what I want to do next is upgrade the wheels and brakes. Currently mine has disc in the front and drum in the back. For the front, I believe I will have to change the forks to be able to use more modern callipers, which I am fine with. My main problem is with the rear brakes. I want to get a new wheel however I am at a loss on how to mount a calliper, a master cylinder and foot pedal. My welding skills are non-existent so I was wondering someone else had done something similar with adapters or some way else.
Advice on upgrading wheels and brakes 17 Aug 2023 05:49 #888368
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1628
Howdy. What wheels do you currently have? wire spoked wheels or cast alloy?
For a dual disk conversion often times the entire front end is swapped:  triple tree, forks, wheel, brakes...
First thing to do would be to go to the All-Balls-Racing site to see what other models use the same steering bearing kit, then go from there.
I've never heard of anyone doing a rear disk conversion on a 440, but you're going to need to swap swing arms & probably do some welding for a master cylinder mount and maybe for the brake pedal &/or brake light switch. guessing.  Possible problem is the 440 frame might be too narrow for the donor swing arm. another guess.
The following user(s) said Thank You: drunken_thor
Last edit: by martin_csr.
Advice on upgrading wheels and brakes 17 Aug 2023 06:51 #888369
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
The path of least resistance is to make some adapter plates and install a Ninja EX650 Tokico caliper.  This caliper has dual pistons, both outboard of the wheel side.  Opposing piston calipers are typically too deep, and can hit the wheel spokes.  While you are at it, an aftermarket disc can also be used.
On the rear, where there is very little braking force generated, there isn't much advantage to installing a disc.  Particularly on a small and light 440.  I'd leave  well enough alone, other than getting some quality brake pads.
This thread from the Suzuki site should get the juices flowing and define the path...www.thegsresources.com/_forum/forum/tech...pgrade-on-78-Skunk/=
Advice on upgrading wheels and brakes 17 Aug 2023 07:42 #888375
  • drunken_thor
I have cast alloy wheels, but want to change to some spoked wheels as well. Swapping the swing arm is an idea that I had not had before thanks!
Advice on upgrading wheels and brakes 17 Aug 2023 08:26 #888387
  • martin_csr
The KZ650-CSR had 48-spoke wheels w aluminum rims, single disk Fr brake & Rr drum. 19" Fr & 16" Rr.
The Fr might be a direct swap, but not sure about the Rr.
The KZ1000-CSR had basically the same 48-spoke wheels but triple disks (dual disk Fr brake w Rr disk ).  The disks on those CSR models are unique to each & both had a fat rear tire which might be too wide for the 440 swing arm. a narrower tire might work, though.
There was also a 750-CSR w wire spoke wheels but I think they're 40-spoke w maybe steel rims. single disk Fr w Rr drum brake.
The 440B had 18" wire spoke wheels but Front drum brake.
Advice on upgrading wheels and brakes 17 Aug 2023 08:53 #888388
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2078
If you are really serious about modernizing, then mixing and matching old parts is not the way to get there.
If you want modern, order some Ohlins forks in the appropriate length and with proper spring rates and damping. Add custom billet triple clamps, Brembo radial brakes and a carbon fiber 17 inch wheel and a sticky hyper sport tire. Out back you will need a custom swingarm that is light and strong, a mono shock conversion with a properly set up Ohlins shock, and the afore mentioned brake and tire setup. That is modern.
Advice on upgrading wheels and brakes 17 Aug 2023 08:55 #888389
  • Nessism
  • Nessism's Avatar
Or, buy a MotoGP bike, and shoehorn in a 440 engine!
Advice on upgrading wheels and brakes 17 Aug 2023 09:01 #888390
  • TexasKZ
  • TexasKZ's Avatar
Or for fewer shekels,  www.kawasaki.com/en-us/motorcycle/ninja/...TGROUPLIST-_-VEHICLE
Advice on upgrading wheels and brakes 17 Aug 2023 09:14 #888392
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1823
I guess I best "plead the 5th" on the above
Advice on upgrading wheels and brakes 17 Aug 2023 13:11 #888404
  • TexasKZ
  • TexasKZ's Avatar
As should most of us. I have no qualms about mixing and matching old and oldish parts in the hope of making some improvements in performance, comfort or esthetics, and a large depletion of funds.  However, adding thirty five year old parts to a forty year old motorcycle hardly seems like modernizing to me.
Advice on upgrading wheels and brakes 17 Aug 2023 19:13 #888422
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 310
Yeah but it's still fun to do.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Advice on upgrading wheels and brakes 17 Aug 2023 20:11 #888428
  • TexasKZ
  • TexasKZ's Avatar
Yup.
  • Page:
  • 1
