  • Page:
  • 1
79 kz400 rusty hardware 10 Aug 2023 10:14 #888116
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Thank you received: 138
After carb rebuiding, gas tank and petcock cleaning, I was able to get the bike running and took it for a ride up and down the street. Bike ran well and shifted through the gears fine. So, I'm ready to move on to cosmedic issues. I'm not looking to put much money into this bike. But just get it to a decent looking every rider.
Most the chrome plated hardware is rusted. Looking for ideas on cleaning them up, or inexpensive replacements.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
79 kz400 rusty hardware 10 Aug 2023 14:55 #888131
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 384
For irregularly-shaped items like fasteners and clutch lever adjusters, I like to use a brass wire brush.
Ideally you can put a larger (5"-6") brass wire wheel in a small bench grinder type of device, but if that's not practical you can put a smaller wheel in a handheld drill and clean up parts that way. If you go the drill route, you can cut pieces of angle aluminum to make inexpensive soft jaws for your vise (so you don't damage the threads on the items you're cleaning).
Chrome is harder than brass so this won't damage the existing finish - unless corrosion has already loosened some of the chrome.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
79 kz400 rusty hardware 10 Aug 2023 15:22 #888133
  • JR
  • JR's Avatar
  • Thank you received: 435
Fine steel wool with WD 40
79 kz400 rusty hardware 10 Aug 2023 16:45 #888139
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2684
Evaoprust!
79 kz400 rusty hardware 11 Aug 2023 08:09 #888175
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 310
Evaoprust!
Evaporust, drop the rusty parts in. Come back in a day or two depending on how bad the rust is. Evaporust works best warm.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
79 kz400 rusty hardware 11 Aug 2023 09:15 #888179
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 258
Yes - evaporust works great.  It's reusable several times (turns darker as you use up its strength), and it's water based so you can dispose of easily.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
79 kz400 rusty hardware 12 Aug 2023 04:13 #888204
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Tried a new green product / rust remover.
Made for the "PB Blaster" People. It actually works!!
I miss my 5 Gal. bucket of phosphoric acid in crystalline form from work! I retired in 2011. Lasted me 7-8 years.  We used it in our boiler room.
Like the other's said. It turns black after it's used up.
I gathered up some old chrome  Z1 parts. A day soak, in basement. No fumes!
$27 for a gallon at the Orange-Commi-Depot store.
The following user(s) said Thank You: ThatGPzGuy, sf4t7, Grcko
79 kz400 rusty hardware 12 Aug 2023 12:40 #888217
  • sf4t7
  • sf4t7's Avatar
Thanks Marty.  I'm about to soak some parts in Evaporust, I'm gonna get some of the Blaster stuff and try them side by side.  Looks like the Blaster may be better on chrome or painted parts.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
79 kz400 rusty hardware 15 Aug 2023 06:35 #888278
  • z1kzonly
  • z1kzonly's Avatar
Scotty
Hi Scotty, don't put painted items in rust remover.
79 kz400 rusty hardware 15 Aug 2023 07:00 #888280
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 374
Depending upon level of rust/oxidation I have used aluminum foil and soda/pop/coke to remove light levels.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
  • Page:
  • 1
