  • Page:
  • 1
KZ750 Spectre Air shock swap? 03 May 2023 19:51 #884218
  • kz750spectre
  • kz750spectre's Avatar Topic Author
  • Thank you received: 3
Greetings all,
My 1982 KZ750 has air shocks in the rear that seem to be blown. I know some other versions of the KZ750 have normal spring type shocks, can I just swap them on? If so does anyone know where I could buy some, or have a cross referenced part number? I can look up the factory part number in the service manual if you need.
Thanks a bunch
-KzJM
-KzJM
KZ750 Spectre Air shock swap? 04 May 2023 18:03 #884245
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2080
Member ghostdive reported using KZ900 shocks on a 750 shaft with great success, though they are a touch longer than the air shocks. If the air shocks are the same length as the other 750 models, Progressive should be able to solve your problem.
www.progressivesuspension.com/product/1485/12-series-dampers
The following user(s) said Thank You: kz750spectre
KZ750 Spectre Air shock swap? 05 May 2023 08:52 #884277
  • kz750spectre
Thank you very much. I wonder if ghostdive had to modify those shocks for proper fitment? Is there a link to that post?
-KzJM
-KzJM
KZ750 Spectre Air shock swap? 05 May 2023 14:41 #884292
  • TexasKZ
  • TexasKZ's Avatar
As I recall, it was just a response to another post without any further information.
KZ750 Spectre Air shock swap? 15 May 2023 10:20 #884711
  • kz750spectre
Bump
 I've seen some kz750 spectre models with traditional shocks, anyone know about this?
-KzJM
KZ750 Spectre Air shock swap? 15 May 2023 18:08 #884733
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2683
Your bike doesn't NEED air shocks.  As long as the shocks installed are the correct length, and have the proper amount of travel, you should be good.
There are many different shock manufacturers to consider.  Hagon, Ikon, YS, Progressive, and no doubt, others.
  • Page:
  • 1
