  • Page:
  • 1
  • 2
KZ650C rear disk brake 29 Apr 2023 17:56 #883971
  • sflesch94
  • sflesch94's Avatar Topic Author
  • Thank you received: 2
Hi everyone, the service manual I have only covers rear drum brakes. I have rear disk on my kz650. Wondering if there is a trick to removing and installing the rear caliper. Trying to slide it over the rotor and rear brake mount is very difficult, and I feel like I am damaging the rubber seals on the caliper mount holes.
Last edit: by sflesch94. Reason: Picture
KZ650C rear disk brake 29 Apr 2023 18:38 #883973
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2093
Did you remove the axle first?
The following user(s) said Thank You: sflesch94
KZ650C rear disk brake 29 Apr 2023 18:44 #883974
  • TexasKZ
  • TexasKZ's Avatar
Perhaps the 650D rear disc brake is the same. If so, this manual may help.
www.kzrider.com/modules/ServiceManuals/K...l%20KZ650%201981.pdf
KZ650C rear disk brake 29 Apr 2023 18:45 #883975
  • sflesch94
Yes I had the wheel off, but I removed the caliper alone, not the caliper mounting bracket. Now putting it back is giving me issues.
KZ650C rear disk brake 29 Apr 2023 18:49 #883976
  • TexasKZ
  • TexasKZ's Avatar
According to Partzilla, the 650C and D rear brake assembly has the same part number, so the manual linked above should have the correct rear brake info for your bike.
KZ650C rear disk brake 29 Apr 2023 18:52 #883977
  • TexasKZ
  • TexasKZ's Avatar
Ok, thanks. I hope the manual has a solution for you. I suspect one of the 650 owners here will be along shortly with some sage advice .
Last edit: by TexasKZ.
KZ650C rear disk brake 30 Apr 2023 01:18 #883983
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1914
Are the pistons nad pads pushed back fully - if so there should be no resistance sliding the calliper over the disc. Have you replaced any parts and if so what with ?
KZ650C rear disk brake 30 Apr 2023 07:18 #883988
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 261
You need to remove the caliper and bracket as one piece, with it off the bike then remove the pads then you can remove the caliper from the bracket.
Installing the caliper on the bracket can be trickey with those 4 rubber dust seals make sure you have new ones on hand and don't get any grease on the inside of the dust seals it's a tight fit and if I remember correctly the caliper will only go on the bracket in one direction and the bracket needs to be off the bike when reinstalling the caliper back on the bracket.
New dust seals can be had at brakecrafters.com
Last edit: by Moose1800.
KZ650C rear disk brake 30 Apr 2023 07:45 #883992
  • sflesch94
Yeah I didn’t remove the mounting bracket. I got the caliper off somehow though. Here is where I am at. I don’t really see how the bracket being off the bike will be different, the part I’m having trouble clearing is those dust boots. Maybe I need to coat them with a little grease so the caliper slides over easier.
KZ650C rear disk brake 30 Apr 2023 08:08 #883997
  • Moose1800
With the mounting bracket off the bike you will be able to see the dust seals go into place, it's very easy to tear the dust seals when installing the caliper on the bracket or they fall off before going into place and you won't be able to see it. It's no big deal to remove the bracket your almost there. Their isn't much holding the dust seals on the bracket and it can be frustrating trying to get the caliper on the bracket even with the bracket off the bike. You can try it your way you might get lucky but good luck.
Also if you use grease you need to use brake grease and use it sparingly and grease the caliper bolts to.
KZ650C rear disk brake 30 Apr 2023 10:13 #884000
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1884
Moose1800 has the correct advice. Pull the axle and remove the bracket. Assemble the caliper and install as a unit.
KZ650C rear disk brake 30 Apr 2023 17:11 #884020
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 318
My early(#442) 77' KZ 1000LTD has the same rear brake setup as your bike. The manual says it is different but I know it's original. It seems like the mounting bracket only goes in from one end of the caliper or it knocks the slider pin boots off. It took me a few tries to get it and I tore a boot in the process, order a couple extras.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
  • Page:
  • 1
  • 2
