  • Page:
  • 1
KZ900 Rear Brake Upgrade 04 Apr 2023 17:54 #882516
  • mark3592
  • mark3592's Avatar Topic Author
  • Thank you received: 0
Hello,
I’m currently building a KZ900 that I acquired.   I’m going to add an extended Swingarm, probably around 4” .   I’m wanting to eliminate the caliper brake arm to clean up the look & not have the interference of larger tire.   I’m wondering if anyone has done that possibly with Brembo disc & caliper kits.
KZ900 Rear Brake Upgrade 05 Apr 2023 09:54 #882536
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1884
One member solution. You will also have to weld on a mount for a rear master cylinder, unless you use custom rear sets with the MC attached.
www.kzrider.com/forum/11-projects/617360...enix-reborn?start=36
KZ900 Rear Brake Upgrade 05 Apr 2023 11:31 #882541
  • BohicaBob
  • BohicaBob's Avatar
  • Thank you received: 35
I installed a Suzuki GS1100 swingarm, '77-'78 rear brake rotor and caliper, and a KZ rear brake master cylinder on my 1973 Z1-900.  I made a mount for the rear brake master cylinder that bolted on the thick aftermarket right engine mount.
The following user(s) said Thank You: Wheelhop
Last edit: by Street Fighter LTD.
KZ900 Rear Brake Upgrade 07 Apr 2023 17:17 #882638
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 302
looks good Bob!  How about some more pics?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
  • Page:
  • 1
