Clicking sound from front bevel gears
- Will2000
18 Mar 2023 17:55
Hi all, I have a 1983 kz1100 shaft. And I noticed when in first gear, the rear wheel has a few inches of play, and it makes a clicking sound every time that it hits the end of the play. The clicking sound of coming from the front bevel gears. Should I be concerned or just a normal type thing?
Re: Clicking sound from front bevel gears
18 Mar 2023 20:43
A few inches is too much. Has the driveline been properly serviced?
- daveo
18 Mar 2023 21:12
Probably normal. That happens when I rock my bike back and forth as the gears all tighten up in both directions, with the engine not running.
Same thing with engine in gear on the center-stand.
1982 KZ1100-A2
The following user(s) said Thank You: Will2000
- Will2000
19 Mar 2023 19:44just to clarify, 2-3 inches of wheel spin at the tire, the engine off, the bike on the center stand, with the rear wheel off the ground. I haven't serviced the drive line, no idea if the previous guy did (although I doubt it). I would assume I need to possibly grease the bevel gears?A few inches is too much. Has the driveline been properly serviced?
- Will2000
19 Mar 2023 19:46thats the exact situation I'm in, bike on the center stand, engine off, and it goes about 2-3 inches of wheel travel when I rock the rear wheel in gear.
20 Mar 2023 00:27 - 20 Mar 2023 02:10
That doesn't seem excessive to me, what does the manual say ref measurements for backlash in the driveline ? If the "backlash" is not in spec it can be adjusted with shims to allow the gears to sit closer together (tapered gears) the below diagram is for the front but I believe the rear can also be shimmed (have the oil in the final drive ever been changed ?)
Last edit: 20 Mar 2023 02:10 by Wookie58.
- Will2000
20 Mar 2023 12:46Just changed the final gear case oil, Great idea to look in the manual I don't know why I didn't think of that. Unfortunately, I wasn't able to find the specs relating to the final driveline in the service manual (it seems to only address the chain drive). If it gets worse I can start tearing into it. Thank you for your help! I didn't realize it could be shimmed up, that is simpler than I expected (compared to replacing the whole bevel gear assembly.That doesn't seem excessive to me, what does the manual say ref measurements for backlash in the driveline ? If the "backlash" is not in spec it can be adjusted with shims to allow the gears to sit closer together (tapered gears) the below diagram is for the front but I believe the rear can also be shimmed (have the oil in the final drive ever been changed ?)
