  • Page:
  • 1
  • 2
Struggling trying to remove the side stand. 20 Nov 2022 10:38 #877000
  • Missile2511
  • Missile2511's Avatar Topic Author
  • Thank you received: 2
Hello all, I am trying to remove the side stand on my 1979 kz 650b3 and I am having a hard time drilling out the pin that holds it on. Is there a secret to this?
Thanks,
Joe
Struggling trying to remove the side stand. 20 Nov 2022 10:49 #877002
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1788
Thanks,
Joe
Why are you using a drill rather than a spanner ????
Struggling trying to remove the side stand. 20 Nov 2022 12:50 #877006
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Remove the nut, remove the bolt, and it will come off easily. You will probably want to remove the spring first. Be careful, it is pretty stout.
No drilling needed.
Last edit: by TexasKZ.
Struggling trying to remove the side stand. 20 Nov 2022 14:38 #877007
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
No drilling needed.
PS: Don't forget the inner hole is threaded, once the nut is off you need to unscrew the bolt (you can't take the nut off and knock the bolt through)
Struggling trying to remove the side stand. 20 Nov 2022 15:52 #877009
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
I don't know what pin there would be. The diagrams don't show a side stand pin & the main stand should have a cotter pin.
To remove the spring deploy the stand, place pennies between the coils, then retract the stand & remove the spring. or something like that. Wear eye protection.
www.partzilla.com/catalog/kawasaki/motor...3/stands-brake-pedal
The following user(s) said Thank You: 78z1Joe, Street Fighter LTD, sf4t7, Wookie58
Struggling trying to remove the side stand. 20 Nov 2022 15:57 #877010
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
That's a great tip
Struggling trying to remove the side stand. 21 Nov 2022 10:18 #877036
  • Missile2511
Thanks for all of your replies. I realize now that you are all correct, but someone beat me to it and found that the bolt is stripped and simply spins when you try to turn it out. They cut the head off and  attempted to drill it out and found that the bit simply spins the bolt. I need a way to stop the bolt from spinning while I drill it out and I am not equipped to spot weld it from behind.
Joe
Struggling trying to remove the side stand. 21 Nov 2022 10:20 #877037
  • Missile2511
Same guy cut off the back of the bolt and there is nothing to grab onto to stop it from spinning.
Struggling trying to remove the side stand. 21 Nov 2022 10:38 #877039
  • martin_csr
A couple of pics might help.  Is the nut still on the bolt?  If so, would it be possible to cut it off w a mini hacksaw. maybe jam something between the bolt & side stand to keep it from spinning?
Last edit: by martin_csr.
Struggling trying to remove the side stand. 21 Nov 2022 10:47 #877040
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 656
If the thread is stripped and the nut has been cut off you should be able to just tap out the bolt from behind using a suitable drift.
Z1000J2 somewhat modified!
Struggling trying to remove the side stand. 21 Nov 2022 11:36 #877043
  • Missile2511
Thanks again. I like the idea of tapping it out from behind. I have already cleaned off the last remaining thread on the end of the bolt with a grinding wheel, but I was not able to tap it out. I am going to lift the back of the bike up a few feet with a chain fall so that I get some leverage and test that idea again.
I will let you know what happens.
‘Thanks,
‘Joe
Struggling trying to remove the side stand. 21 Nov 2022 11:42 #877044
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Just out of interest, is there enough of a gap between the stand and the bracket to get a hacksaw blade in (you should be able to apply enough sideways pressure on the stand to stop the bolt spinning while you cut it) whichever way you go will be a PITA at this stage.!
Space permitting you may also be able to push it out from behind with a two legged puller (they aren't expensive)
got to love the PO (why would you cut the head off a bolt that turns !!!!!!!!)
The following user(s) said Thank You: Nerdy
Last edit: by Wookie58.
  • Page:
  • 1
  • 2
