long shock bolt
- kdoggin
long shock bolt
24 Jul 2021 18:44Please Log in or Create an account to join the conversation.
Re: long shock bolt
24 Jul 2021 19:09
It’s not to long. The seat stay and washers take up the room. As far as the other you can have a piece welded on. I suggest cutting the broken one back so the welded butt joint is under the shock eye. Then you can cut the piece to length and thread.
The following user(s) said Thank You: kdoggin
- kdoggin
Re: long shock bolt
24 Jul 2021 19:17
I was thinking along those lines, great idea to weld it under the shock, l'll leave a little extra existing stud to support the weight. Any chance u have a pick of the seat stay and washers in action. Thanks in advance !
Re: long shock bolt
24 Jul 2021 19:29
Look here
www.partzilla.com/catalog/kawasaki/motor...-arm-shock-absorbers
. The seat stay fits in between the #21 washers. Seat stay is #18 here
www.partzilla.com/catalog/kawasaki/motor...1/fenders-seat-cover
- 750 R1
Re: long shock bolt
24 Jul 2021 21:20
You could also just cut the threaded piece off the other side and drill and tap whats left and fit button head bolts, I'm doing that on my build, That is of course if you don't mind it not being stock...
- kdoggin
Re: long shock bolt
25 Jul 2021 03:47
Now I see Mikaw, I don't have the seat stay, but was thinking about getting one, guess its off to Z1E. Thank You!
