z1r rear brake drags
  • david richard
  • david richard's Avatar Topic Author
20 Jun 2021 00:36
#850440
hi i have a question i have renewed the caliper seals the pistons are in good order and no crud in the groves rubber grease used i the piston push in easy i filled a bit off the side of the pads so they are not tight in the caliper yet when i spin the wheel the brakes are just binding a bit the same as it did with the old seals in it the master cylinder was all cleaned 3 years ago and i use silicon brake fluid .i was thinking is it because it only relies on one seal rather than two on a modern bike oh and the rear brake is adjusted right with a small play before it pushes the rod ,any thoughts thanks.david
  • TexasKZ
  • TexasKZ's Avatar
Re: z1r rear brake drags
20 Jun 2021 04:21
#850442
It could be that the pressure relieve port in the master cylinder is clogged. It is very tiny and often overlooked. Seems like there was a thread with pictures about it some months ago.
The following user(s) said Thank You: david richard
  • 73z1
  • 73z1's Avatar
20 Jun 2021 04:25
#850443
Some drag is normal so it depends how much drag there is.
To much drag disassemble and clean both cylinders.
  • TexasKZ
  • TexasKZ's Avatar
20 Jun 2021 04:30
#850444
Here is the thread. In this picture you can see both holes. The tiny one I am talking about is below the larger one.
www.kzrider.com/forum/5-chassis/613477-1...tuck?start=12#829701
  • TexasKZ
  • TexasKZ's Avatar
20 Jun 2021 04:35
#850445
Yes, indeed. If the wheel is still easy to turn by hand after applying and releasing the brake, it is probably fine. If the wheel is difficult to turn by hand, or it gets progressively more difficult with each application and release of the brake, then something needs attention.
  • bluej58
  • bluej58's Avatar
20 Jun 2021 05:51 - 20 Jun 2021 05:52
#850449
Have you checked the adjustment bolt for the foot lever?
If it is spun out too far it will keep the lever pressed down and prevent the fluid from returning to the  reservoir causing a build up of pressure in the caliper
78 KZ1000 A2A
Last edit: 20 Jun 2021 05:52 by bluej58.
  • david richard
20 Jun 2021 06:14
#850452
hi thanks for you imput  its difficult to describe how it feels but 73 z1 comments is a good way to word it ,i thought  it  would turn easy with no drag  with  new seals in it  when i push the pads in further there is no drag at all ,i will have to look into it ,,david
  • TexasKZ
  • TexasKZ's Avatar
20 Jun 2021 19:27
#850503
Also, be sure that the lever moves freely. The pivot can collect dirt and rust which can cause the lever to not return properly.
  • david richard
20 Jun 2021 22:32
#850511
hi texaskz for all your replies yes i restored the bike 3 years ago and it never goes out in the rain i remember greasing the shaft  but i will look into it ,david
  • david richard
27 Jun 2021 09:36
#850801
a quick follow up to my problem a took the master cylinder apart today and it was all blocked up with the crystalised stuff in there which texas kz  thought ,,many thanks
  • TexasKZ
  • TexasKZ's Avatar
27 Jun 2021 16:28
#850811
Glad you found the problem. Let us know how it comes out.
