  • Page:
  • 1
Front master cylinder sight window 15 Jun 2021 14:00 #850239
  • Claude.
  • Claude.'s Avatar Topic Author
  • Thank you received: 34
The sight window on the front brake master-cylinder of a KZ750L3 I'm currently restoring is quite yellowish and I would like to replace it. On partzilla, I see that it was not available by itself but can it be replaced anyway? Any other source for this part? (OEM from another model or jobber)
I know I could replace the whole master cylinder but for now, I'm only looking for the sight window.
Thanks!
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
1982 KZ1000J2 (another one!)
2017 Yamaha FZ07
Front master cylinder sight window 15 Jun 2021 15:59 #850242
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2678
Did a google search and this was at the top...
The following user(s) said Thank You: Mikaw, Claude.
Front master cylinder sight window 15 Jun 2021 16:43 #850248
  • Claude.
Thanks Nessism! I'm not afraid by the procedure; I already replaced the engine oil sight glass on the clutch cover on one of my previous ZX-11. The unit was available from Kawasaki and it was held in place by the pressure of the built-in o-ring.
What I mainly am looking for in my KZ750 project is a source of the master-cylinder's glass itself as it is not listed on Partzilla or Kawasaki's online parts catalogs.
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
Last edit: by Claude..
Front master cylinder sight window 15 Jun 2021 19:12 #850251
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 133
No eBay APP ID and/or Cert ID defined in Kunena configurationI replaced both clutch and brake sight glasses on my Magna eight years ago with these. They are real glass, not plastic. So should never yellow. I don,t know if they fit your bike.
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
The following user(s) said Thank You: Claude.
Front master cylinder sight window 15 Jun 2021 22:42 #850257
  • woodyvale
  • woodyvale's Avatar
  • Thank you received: 18
This guy on ebay replaces them
Or you can do it yourself and buy the glass to size. I did my gpz1100 and its still fine after 3 years. I bought the sight glass kit from 'new river cycle salvage llc'
They advertise on ebay and if you can't see your bike listed you can contact them and they will make to size.
Front master cylinder sight window 17 Aug 2021 12:30 #853959
  • Claude.
I just ordered glasses from "New River Cycle Salvage llc". They have the ~22 mm diameter glass I need for the KZ750.
Many thanks for the information!
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 GPZ1100
1983 KZ750L
2017 Yamaha FZ07
Front master cylinder sight window 18 Aug 2021 07:02 #854006
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1622
Yamaha/Nissin sight glass pdf >>  www.xj4ever.com/choosing%20a%20sight%20glass.pdf
I have no idea if anything in this pdf would be useful for a vintage Kawasaki master cylinder.
tags. mineral glass. glass button. site glass. plastic sight barrel.
Related. The 650-CSR & 750H Ltd master cylinder sight glass is encased in a metal ring & rubber seal (~25mm). Z1Ent sells a 25mm oil level gauge sight glass, but I have no idea if either the whole thing or just the glass & seal could be used w a master cylinder.
Last edit: by martin_csr.
  • Page:
  • 1
