KZ750 front end swap 17 Sep 2020 08:25 #835221
  • Ethan B
  • Ethan B's Avatar Topic Author
  • Thank you received: 0
Hi everyone!
I recently bought a KZ750 from 1981. I'm on my way to do a front end swap on it. I'm looking for the easiest fit on as possible. I have the opportunity to buy a 06 zx10r complete front end ( forks, triple tree, wheel, brakes, masters etc.). I was wondering if this is a good idea? Should I be worried about the forks being to wide and knocking on the frame while turning? What's y'all opinions and idea?
Thank you, Ethan
KZ750 front end swap 17 Sep 2020 12:29 #835228
  • davido
  • davido's Avatar
  • Thank you received: 286
More likely hitting the tank than the frame. I had to widen the head lock stop (?? Cant remember the right word!!) on my CSR when I fitted the ZX9r forks. It reduced the turning range (Bollocks! Wheres my brain? I'm losing terminology!!) Not by very much and its not really noticeable except when you're trying to park.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: Ethan B
KZ750 front end swap 17 Sep 2020 12:46 #835229
  • Ethan B
Should I try to space up the tank a bit or just switch up to another type of front end? I heard about Suzuki's inverted forks, could it be an option? Or am I going to have the same problem? I heard that the zx6r and zx9r are easily bolt on on these kind of bikes, it that right?
KZ750 front end swap 17 Sep 2020 13:53 #835232
  • davido
  • davido's Avatar
No idea about your specific bike but this is one of the joys of bike building. How to get something to fit that wasn't designed to fit. Be prepared for many of these magical moments.
Like I said with mine,I was lucky and got away with it. Don't know what I would have done otherwise. I never even considered that it might be a problem. I know that some old cafe racers used to hammer dimples into the front of the tank to accommodate clip ons. It might work but a bit drastic though.
If you have access to the ZX10, you could measure the top yoke and make a copy out of wood. Offer it up to your bike and see how much of a turn radius you get. Lifting the tank might work but it would probably ruin the lines of the bike and look crap. Don't know. Maybe others here have a suggestion.
More things to think about are matching the wheels. If you use the ZX front wheel what are you going to do on the back? Will the ZX rear wheel fit? What swingarm to use? How to deal with the chain offset?
Also, ground clearance. Expect the new forks to severely lower the front end. Whats that going to do to your exhaust downpipes. I used the ZX9r forks which were meant to be the longest of the Jap USD at the time. I still had clearance problems and had to fit extensions to the fork tops to bring everything up a bit. (So, if you get a chance to measure the top yoke,you should also measure the fork length with the wheel to see what your,e in for.)
There are many more of these issues to think about, the ones above are just what comes to mind right now. Best thing to do is read as many build threads as you can. A lot of people here have gone through the same thing and there's a lot of info on what can happen and how to get over it.
Good luck.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
KZ750 front end swap 17 Sep 2020 18:19 #835244
  • Ethan B
Thank you very much man I appreciate the help! Will try ton keep the post up to date as I'm working on it! Will work hard to make it good!
Thank you!
KZ750 front end swap 18 Sep 2020 07:02 #835259
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
I read somewhere that the ZX 636 has the longest forks of the Ninja family. This may eliminate the need for custom clamps and fork extensions. The mid-90s GPz 1100 also had pretty long forks, but they may be hard to find.
If you find a front end that is close in length, and has the offset and rake & trail you are looking for, you may be able to get away with putting the KZ steering stem in the new lower clamp, thus retaining the stock size steering bearings.
There are a lot of variables involved.
KZ750 front end swap 18 Sep 2020 14:37 #835313
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Sorry TexsasKZ but the ZX9-R (94-95 four piston caliper) and the ZX-9R (96-97 six piston caliper) are the longest forks of the Ninja family.
The following user(s) said Thank You: TexasKZ, Mikaw
KZ750 front end swap 19 Sep 2020 06:23 #835340
  • TexasKZ
  • TexasKZ's Avatar
Second place ain't so bad.......
KZ750 front end swap 19 Sep 2020 06:25 #835341
  • TexasKZ
  • TexasKZ's Avatar
Oops, early 6R at 758 and ZZR 14 at a whopping 742 beat it as well.
KZ750 front end swap 19 Sep 2020 09:50 #835353
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Sciricco
How is the measurement taken. Center Line of axle to to top of upper tube?
KZ750 front end swap 19 Sep 2020 11:22 #835355
  • Saablord
  • Saablord's Avatar
  • Thank you received: 59
Mikaw wrote: Sciricco
yes.
and zx9 forks can be extended. kzrider.com/forum/5-chassis/611307-lengt...ks-for-zx-to-kz-swap i will have stock ride height on my 78 650 project with zx9 forks.
KZ750 front end swap 19 Sep 2020 13:04 #835361
  • Mikaw
  • Mikaw's Avatar
yes.
Thanks, Im thinking about starting a new post so this one stays intact.
Last edit: by Mikaw.
