Petcock Compatibility, Filter screen sourcing, 81 KZ1100-A1
- ScooterZ
22 May 2020 21:32 - 22 May 2020 21:36
Hi guys, I have a petcock that the PO jimmy rigged the filter screen (see picture).
1) Does anyone have or know where to source the filter screen for the petcock?
I saw a picture of the petcock for a 2005 KZ1000POlice model. It looks exactly like the one from my 81.
2) Does anyone have a compatibility chart to show what petcocks will fit my 81 KZ1100 shaft?
3) Can someone with a 03 to 05 KZ1000Police model measure the bolt hole spacing for the Fuel Valve AKA petcock? Mine measures 44mm.
Thanks in Advance for your advice and help,
Scott Z
Scott Z
Attachment not found
ScottZ
1981 KZ1100A1 Shaft
1981 KZ1100A1 Shaft
Last edit: 22 May 2020 21:36 by ScooterZ. Reason: trying to add a pic
Re: Petcock Compatibility, Filter screen sourcing, 81 KZ1100-A1
22 May 2020 21:49
Here is a fitment list. I was a little surprised that it is not the same part for all of the KZ1000 and 1100 models from 1981 onward. I wonder whatt the difference is. I do not know of a source for just the filter screen.
www.partzilla.com/product/kawasaki/51023...4ad5a6bb516ee42ac469
The following user(s) said Thank You: ScooterZ
- ScooterZ
22 May 2020 22:07
Thanks, Yes, the part # is 51023-1174 but hey are currently unavailable.
The part # for the new one I saw listed on ebay is 51203-1375 for an 02 to 05 KZ1000Police. It looks exactly like the one from my 81. so I was wondering if anyone has compiled compatibility lists to use newer parts for unavailable ones.
Z
Z
ScottZ
1981 KZ1100A1 Shaft
1981 KZ1100A1 Shaft
- cb900f
22 May 2020 23:17
This isn't going to be much help, but I was looking for a screen for my ZN1300 a couple of years ago (not sure if it's the same as the one your tap should have but it looks like it would be very close). In any case, I wasn't having any luck, then at a swap meeting I found a guy who had a box of tank filters and I found one that fit my tap perfectly. The screen was for a different bike and the guy sadly had no idea what it was from. The point is, they are out there - but finding them is the problem.
Here are the dimensions of a ZN1300 Fuel tap/tank interface:
And the screen I found (I had to pull that tube out of it)..
- ScooterZ
23 May 2020 08:24
Thanks CB900f, That looks like what I need to find. The dimensions you show are similar to my petcock. As you can see in my pic the PO jimmy rigged a Papermate pen body to work. Unfortunately the reserve screen is torn so essentially useless. I may be forced to reuse my fuel petcock as is. It does work. An in line fuel filter will be needed.
Scott Z
Scott Z
ScottZ
1981 KZ1100A1 Shaft
1981 KZ1100A1 Shaft
- cb900f
23 May 2020 13:45 - 23 May 2020 13:46
The problem with the ZN1300 tap design, yours looks similar, is without a sediment bowl, any crap that gets through the tap filter (or lack of filter) can collect in the tap internals causing them to bind, making operation difficult, and gradually wearing out the selection cone (the thing that directs fuel flow from either: normal or reserve inside the tap).
Last edit: 23 May 2020 13:46 by cb900f.
23 May 2020 15:15
If your 1100 also has 44mm spacing, I don't know why any other 1000/1100 petcock would not work.
23 May 2020 15:26
Z1E has one that fits them all.
www.z1enterprises.com/petcock-kz1000k44-...0-kz650h-kz750h.html
They also list a couple for Suzukis with 44mm spacing for less money, and I bet the just might work, too.
24 May 2020 06:38 - 24 May 2020 11:21
KZ1000P petcock. I think the bolt hole spacing is 44mm. New oem are still available. 51023-1375
It's the same one listed at Z1Ent linked by TexasKZ. The partzilla pic doesn't show the screen, but I'm pretty sure it's included.
www.partzilla.com/catalog/kawasaki/motor...uel-tank-p21-p22-p24
Last edit: 24 May 2020 11:21 by martin_csr.
24 May 2020 07:35The vacuum operated valves on the 1000 and 1100 use a completely different valve design than your 1300 valve. The newer design is not as sensitive to fine dirt as the cone style valve. Typically, dirt will prevent the little oring from sealing, but that is easily cured with a careful clean and polish of the internal parts, and a fresh oring.cb900f wrote: The problem with the ZN1300 tap design, yours looks similar, is without a sediment bowl, any crap that gets through the tap filter (or lack of filter) can collect in the tap internals causing them to bind, making operation difficult, and gradually wearing out the selection cone (the thing that directs fuel flow from either: normal or reserve inside the tap).
The following user(s) said Thank You: cb900f
- ScooterZ
30 May 2020 19:47
Thanks for the input guys. I have ordered a Kawasaki 51023-1375 for the 02 to 05 KZ1000Police model. I am waiting for Partzilla to deliver but they seem to be dragging their feet.
My project is progressing. That means I am taking apart more and more pieces, cleaning, detailing and replacing what needs to be replaced. I am impressed how many parts are still available.
The bike is very original and even most of the rubber pieces are in great shape. I will eventually take almost everything apart but will probably leave the engine in the frame as it ran well , with low mileage, prior to beginning the project.
Of course I will spend more than it is worth but will have a real nice bike when I am done. It's a labor of love as many of you know..
ScottZ
1981 KZ1100A1 Shaft
1981 KZ1100A1 Shaft
