  • Page:
  • 1
'79 KZ650-C Tire Question 28 Mar 2020 12:56 #822031
  • mjudge
  • mjudge's Avatar Topic Author
  • Thank you received: 0
Hi All:
My '79 KZ650-C has an 18" rear wheel with a 4.00 / 18 tire and rear disc; will a 16" wheel with a 4/00 / 16 tire and rear disc from an '82 KZ750 Spectre work on this? Seems I remember my '78 KZ650-B2A had a 16 inch rear wheel, although it was a drum. Front is a 3.25 / 19 with dual discs. Thanks!
'79 KZ650-C Tire Question 28 Mar 2020 13:08 #822033
  • Thank you received: 2829
Who knows, but why on Earth would you want to do that to the bike? :blink: BTW, the KZ650-B2A came with an 18" spoke (not cast like the C models) rear wheel. Ed
Last edit: by 650ed.
'79 KZ650-C Tire Question 28 Mar 2020 14:30 #822048
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
I don't know if a shaft drive rear wheel will work on a chain drive model, but I would guess not. just a guess.
A chain drive rear wheel will probably be a better fit. closest match is probably a 70s 650-SR. A 750H Ltd might also work.
The 650B came stock with an 18" Rr.
'79 KZ650-C Tire Question 28 Mar 2020 16:02 #822061
  • mjudge
Thank you all! Just going to bite the bullet and go new on the tires.
  • Page:
  • 1
