  • Page:
  • 1
HELP ID FRONT END 02 Mar 2006 18:44 #27684
  • JUSTICE114
  • JUSTICE114's Avatar Topic Author
  • Thank you received: 1
I have a 77Kz1000 and need a front end. What can i put on it, besides the stock, with out having to do much modifications?????
Post edited by: JUSTICE114, at: 2006/03/02 21:45
Post edited by: JUSTICE114, at: 2006/03/05 16:27
HELP ID FRONT END 02 Mar 2006 18:46 #27685
  • wireman
  • wireman's Avatar
  • Visitor
whats wrong with your stock front end?:whistle:
HELP ID FRONT END 02 Mar 2006 19:10 #27697
  • JUSTICE114
HEY BRO YOUR ALL OVER DA PLACE!:lol: WHEN I WRECKED I TWEAKED THE FRONT END A LIL.
HELP ID FRONT END 02 Mar 2006 19:14 #27700
  • wireman
  • wireman's Avatar
  • Visitor
let me know if you want to get rid of it.;)
HELP ID FRONT END 02 Mar 2006 19:27 #27709
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
  • Thank you received: 29
If it's only tweaked a little bit (no creases in the upper tubes) you might want to check with a bike shop near you.
A lot of shops will send out forks/wheels/frames for straightening to help save customers from having to replace them.
I had the forks and front wheel straightened on a GPz550 I had crashed in '86, you couldn't even tell they had been bent afterwards. B)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
HELP ID FRONT END 02 Mar 2006 19:38 #27722
  • JUSTICE114
THANKS 4xR!!!!
HELP ID FRONT END 03 Mar 2006 03:23 #27790
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
  • Thank you received: 35
Where are you located?
HELP ID FRONT END 03 Mar 2006 07:05 #27826
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
Justice114, Lose the "all caps" typing. On the internet, caps are considered SHOUTING and make the post hard to read. Anyway, to answer your question, you didn't mention which bike model you own. I think some KZ1000s use different diameter fork tubes. The easiest way to get around this is to buy the WHOLE front end off a bike. Get the trees, forks, fork lowers and brakes with the splitter and master cylinder. That way, you can just swap the whole mess. The other way you can do this is to go to www.buykawasaki.com and look at diagram for the forks and see what other models share that part number. I have the forks from a 74 or 75 Z1 on one of my 76 KZ900 carb test bikes using the 76 trees but I had to use the Z1 caliper/rotor as well as the mount is different. On my other carb test bike, I got the whole front end including trees/brakes from a 79 LTD. If I am not mistaken, the LTD forks are a bit thicker but I can't swear to it.
HELP ID FRONT END 05 Mar 2006 13:29 #28434
  • JUSTICE114
My bad bro. Sorry bout the caps, force of habit. Thanks for the info for the front end.
  • Page:
  • 1
