my bike is going to be track only. not building for a class of any sort. i want it to launch straight, be stable at speed, and stay together.
i only want to go and run numbers for myself. just to see if i can do it. a personal goal, if you would. i have the power plant, and it really belongs in a track bike.
i was talking with a local guy who races today, wire, you might know him. jim t. down at c&c cycles. anyways, his info is 6-7 degrees over stock rake, lower the forks or no, just get the bike level front to rear. i'm gonna run a fairly small tire, and i have the facilities to back-half it, so i will build for more in the future.
so, yeah, that's the plan.
wire, when you raised the rear end of that zook, you shortened the wheelbase some, and the rake/trail. that would explain the benefit to your steering.
lorcan, sounds like you do a bit of racing. what type of bike/class do you run in?
i'll be building another bike once i have this drag project done. i'll have a second frame that i plan on updating with newer suspension, running a 1200 n/a motor, and generally having fun with.
--r
