- Thank you received: 4
z1r electrics
- Lotus54
13 Jul 2024 18:54 #902067
by Lotus54
z1r electrics was created by Lotus54
I am looking for a high resolution scan of the wiring diagram (similar to above) supplement 313 KZ1000 D3.
I have one, but just not good enough scan to read well. It appears to match the closest.
thanks,
Mark
thanks,
Mark
- gd4now
- Denco where did you go?
- Thank you received: 429
14 Jul 2024 08:36 #902091
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic z1r electrics
1977 KZ650 B1
The following user(s) said Thank You: Lotus54
- Lotus54
14 Jul 2024 09:10 #902096
by Lotus54
Replied by Lotus54 on topic z1r electrics
Thanks! That second one is much easier to read than the others I have.
I think that will do the trick. I just have a couple final things to sort. I bypassed the ‘Reserve lighting’. A buddy that worked at a Kawasaki dealer as a mechanic back when there were new said they had a LOT of trouble with that system.
- DOHC
- Those Doe-Hawks really go!
- Thank you received: 540
14 Jul 2024 09:55 #902100
by DOHC
My dad's '74 Z1
'00 ZRX1100
Replied by DOHC on topic z1r electrics
This site automatically reduces the pixel size of images, or at least it did in the past.
The best way I've found to post high resolution scans is to attach them as a PDF.
If you'd like I can scan the manual at a high resolution and post a PDF.
My dad's '74 Z1
'00 ZRX1100
- DOHC
14 Jul 2024 09:58 #902101
by DOHC
My dad's '74 Z1
'00 ZRX1100
It turns out I already did that in the past:
kzrider.com/forum/4-electrical/617292-19...hazard-issues#863729
My dad's '74 Z1
'00 ZRX1100
- Thank you received: 2053
14 Jul 2024 12:53 - 14 Jul 2024 12:58 #902105
by Scirocco
Put the pic(s) in a ZIP/RAR file, they won´t be re-sized by the site software.
The ZIP/RAR container file protect the files against any kind of changes!
Only the file size of 2 Mb is the limit.
Replied by Scirocco on topic z1r electrics
Last edit: 14 Jul 2024 12:58 by Scirocco.
- DOHC
14 Jul 2024 13:59 - 14 Jul 2024 14:00 #902106
by DOHC
This is true, but many web sites and services either block zip files or show a warning that the file "might be dangerous".
I've never seen any site complain about a PDF.
My dad's '74 Z1
'00 ZRX1100
]Put the pic(s) in a ZIP/RAR file...
My dad's '74 Z1
'00 ZRX1100
Last edit: 14 Jul 2024 14:00 by DOHC.
14 Jul 2024 14:26 #902108
by Scirocco
KZR.com support/allow .ZIP/RAR upload attachments up to 2 mb, so why trouble around with pic to pdf converter apps.
PDF files can also include and execute dangerous codes/scripts.
