z1r electrics
  • Lotus54
  • Lotus54's Avatar Topic Author
z1r electrics
13 Jul 2024 18:54
#902067
I am looking for a high resolution scan of the wiring diagram (similar to above) supplement 313  KZ1000 D3.
I have one, but just not good enough scan to read well. It appears to match the closest.
thanks,
Mark
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: z1r electrics
14 Jul 2024 08:36
#902091
Not sure if this will be of help but here are a couple of wiring diagrams for a D3.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Vinsky, Lotus54
  • Lotus54
Re: z1r electrics
14 Jul 2024 09:10
#902096
Thanks! That second one is much easier to read than the others I have.
I think that will do the trick. I just have a couple final things to sort. I bypassed the ‘Reserve lighting’.  A buddy that worked at a Kawasaki dealer as a mechanic back when there were new said they had a LOT of trouble with that system.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: z1r electrics
14 Jul 2024 09:55
#902100
This site automatically reduces the pixel size of images, or at least it did in the past.
The best way I've found to post high resolution scans is to attach them as a PDF.
If you'd like I can scan the manual at a high resolution and post a PDF.
My dad's '74 Z1
'00 ZRX1100
  • DOHC
  • DOHC's Avatar
Re: z1r electrics
14 Jul 2024 09:58
#902101
It turns out I already did that in the past:
kzrider.com/forum/4-electrical/617292-19...hazard-issues#863729
My dad's '74 Z1
'00 ZRX1100
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: z1r electrics
14 Jul 2024 12:53 - 14 Jul 2024 12:58
#902105
Put the pic(s) in a ZIP/RAR file, they won´t be re-sized by the site software.
The ZIP/RAR container file protect the files against any kind of changes!
Only the file size of 2 Mb is the limit.
Last edit: 14 Jul 2024 12:58 by Scirocco.
  • DOHC
  • DOHC's Avatar
Re: z1r electrics
14 Jul 2024 13:59 - 14 Jul 2024 14:00
#902106
]Put the pic(s) in a ZIP/RAR file...
This is true, but many web sites and services either block zip files or show a warning that the file "might be dangerous".
I've never seen any site complain about a PDF.
My dad's '74 Z1
'00 ZRX1100
Last edit: 14 Jul 2024 14:00 by DOHC.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: z1r electrics
14 Jul 2024 14:26
#902108
KZR.com support/allow .ZIP/RAR upload attachments up to 2 mb, so why trouble around with pic to pdf converter apps.
PDF files can also
include and execute dangerous codes/scripts.
