- Thank you received: 2216
Non bike electrical question
- Online
06 Jul 2024 14:08 #901832
by TexasKZ
Non bike electrical question was created by TexasKZ
I have this cheap little fluorescent light fixture that quit working. I opened it up and found this weirdness. As you can see there is a resistor and small light bulb wired inline between the transformer and switch . What the heck are these for?
- Thank you received: 2053
06 Jul 2024 14:20 - 06 Jul 2024 14:29 #901833
by Scirocco
Replied by Scirocco on topic Non bike electrical question
It looks like a small inductiv coil with a ferrit core ( periodic element Fe = pure iron with no carbon) that excited the glow bulb.
Last edit: 06 Jul 2024 14:29 by Scirocco.
- Kelly E
- Thank you received: 333
06 Jul 2024 15:08 #901836
by Kelly E
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
Replied by Kelly E on topic Non bike electrical question
We skip the florescent tube and replace them with LED tubes and junk the ballast for direct wire. It's way brighter and will use a fraction of the power. We wire in a 1 amp fuse for each pair of LED tubes.
My shop has ten 8' two tube florescent fixtures with two 4' two tube fixtures over tools plus two more 4' two tube fixtures for the wife's garage. We have converted all of them to LED tubes. The shop is much brighter now and the wife doesn't scream about the power bill anymore.
1983 Honda CB 1100F
And more
- Online
06 Jul 2024 15:22 #901837
by TexasKZ
Replied by TexasKZ on topic Non bike electrical question
I have done several of those conversions and changed a fair few bulbs, but never seen that setup before.
- urankjj
- Thank you received: 209
06 Jul 2024 16:27 #901839
by urankjj
Replied by urankjj on topic Non bike electrical question
I would just cover it back up and call it good..
- gd4now
- Denco where did you go?
- Thank you received: 429
06 Jul 2024 18:31 #901843
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Non bike electrical question
How old of a light is it? I think the little bulb is filled with a gas and works as a preheater so to speak and start the bulb glowing.
1977 KZ650 B1
- slmjim+Z1BEBE
- Thank you received: 732
07 Jul 2024 05:14 #901848
by slmjim+Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Replied by slmjim+Z1BEBE on topic Non bike electrical question
Have to concur with that. The neon bulb & other components likely mimic the circuitry of the old-style two-pin 'can' starters that are easily replaced in older fluorescent fixtures.How old of a light is it? I think the little bulb is filled with a gas and works as a preheater so to speak and start the bulb glowing.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Online
07 Jul 2024 06:13 #901850
by TexasKZ
It is an old fixture to be sure, but I do not know how old. That those two parts once performed the function of a can starter seems like a reasonable theory. I may look into converting to led, but I suspect the cost may well exceed a new fixture.
- Thank you received: 2281
07 Jul 2024 08:01 #901854
by Wookie58
Replied by Wookie58 on topic Non bike electrical question
They aren't expensive at all (or don't have to be) I have the below in my shop which have been up for over 2 yeamrs without issue and they cost penny's to runIt is an old fixture to be sure, but I do not know how old. That those two parts once performed the function of a can starter seems like a reasonable theory. I may look into converting to led, but I suspect the cost may well exceed a new fixture.
