  • Page:
  • 1
BATTERY SERIAL 14 Mar 2024 08:20 #896385
  • danr123
  • danr123's Avatar Topic Author
  • Thank you received: 1
hello my battery on my bike is 12 volt     12N12A-4A-1     , I known is 12AH capacity per 10 hr     may be i need a help to describe  exactely this serial number 12N12A-4A-1.thank's and next time
HELLO
MY VINTAGE KAWASAKI KZ400 1978
BATTERY SERIAL 14 Mar 2024 09:48 #896388
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1817
Am I missing something - What is the question ?
The following user(s) said Thank You: Warren3200gt
BATTERY SERIAL 14 Mar 2024 10:48 #896391
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 381
I think he wants some help to understand the meanings of the different parts of the battery model number (maybe so he can find an equivalent battery from another manufacturer).
I don't know exactly what the other fields mean, but that is a Yuasa part number so anything 12V and having the same exterior dimensions should work for what he needs. The other main point will be the location/type of electrical connections on the battery: they will need to be the same as on the current (heh) battery, but there shouldn't be too many options for that.
Here are the details (with a picture of the terminals) from Yuasa: www.yuasabatteries.com/battery/12n12a-4a-1/
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
BATTERY SERIAL 14 Mar 2024 11:59 #896395
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
Here is an explanation of the battery codes.
www.cyclepedia.com/manuals/online/free/e.../battery-size-codes/
The following user(s) said Thank You: sf4t7, howardhb
BATTERY SERIAL 14 Mar 2024 13:50 #896398
  • Wookie58
  • Wookie58's Avatar
  • Moderator
FYI - the AH rating is the amount of current a battery can supply for 1 hour before the residual voltage drops below a pre-determined level so a 12AH battery can supply 12amps for 1hour
BATTERY SERIAL 14 Mar 2024 14:11 #896400
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
The OEM number battery is YB12A-A.  12N12A-4A-1 is the same size and configuration, but seems to be built to a lower price point.
Last edit: by Nessism.
  • Page:
  • 1
