Kawasaki Wire Color Codes
  • Dr. Frankenstein
  • Dr. Frankenstein's Avatar Topic Author
23 Sep 2023 04:57 - 23 Sep 2023 05:16
#889665
I was scrolling through the Topics this morning and came across a post where the author was asking about the black and yellow wire in a Kawasaki wiring harness:
Blk/yel that went to the IC was left hanging - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
I just went through the experience of rewiring a LED headlight on my KZ400H, and I don't know why it didn't occur to me before to dig one up...so I dug around a bit and found this general Kawasaki Wiring Color Code - I hope it helps.
Also (and you probably already know this), before you do anything in the headlight bucket, take the time to take a photo or write down what connectors go to which connectors. The pin connectors are easy, but all those little bullet connectors in there can take you for a ride.  No, you won't remember what wire goes to what wire, and it'll save you a lot of time when you put it all back together. I write them down on a Post-It note and stick it on the fender while I'm working. Saves you a lot of head-scratching. A 17"x 12" (or whatever it is) enlarged color wiring schematic printed out at Staples costs less than two dollars and glued to a piece of posterboard from the Dollar store helps too; it's hard to see what goes where when you're working from just the manual.
Last edit: 23 Sep 2023 05:16 by Dr. Frankenstein.
The following user(s) said Thank You: sf4t7, sdinse
  • sf4t7
  • sf4t7's Avatar
Re: Kawasaki Wire Color Codes
23 Sep 2023 13:13
#889689
Good idea about enlarging the diagram.  Last time I was rooting around in the headlight bucket, I planned ahead (doesn't always happen) and put a small piece of masking tape on both sides of each connector with a number marked on them, so I could match the numbers up when re-connecting the plugs.  I've learned the alternative is having plenty of curse words ready.
Scotty
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
