Electrical Nightmare
  • Cmelton
  • Cmelton's Avatar Topic Author
15 Sep 2023 07:31 - 15 Sep 2023 17:52
#889398
1984 KZ1000P,I have been re-grounding each component, trying to isolate the gremlin that turns on and off at will each light on the motorcycle. The lights work one minute and the next time that I turn the ignition key, they don’t. Its maddening. I have spent hours and hours trying to find the offending connection. Has anyone had this issue, and what was the answer?
Last edit: 15 Sep 2023 17:52 by Street Fighter LTD.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Re: Electrical Nightmare
15 Sep 2023 08:03
#889404
Use a wiring diagram and the guide in the below link, start at the consumer that isn't working and move backwards towards the power source until you find the point that you are losing voltage. Be methodical and logical and it will take hours not days to sort these issues (don't be tempted to short-cut the process)
Electrical fault finding guide - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
  • Cmelton
15 Sep 2023 08:15
#889405
Thank you, I cant open the attachment? I will try it again later.
  • F64
  • F64's Avatar
  • 81-KZ440D2
15 Sep 2023 08:19
#889406
which lights???
all of them?
Does the horn work when the lights go out?
Does the neutral light go out?
Has anything been modified on the bike electrically?
81-KZ440-D2.
LIC, NY
  • Cmelton
15 Sep 2023 17:38
#889427
Still unable to download the guide? Could you check it out?
Thanks,
C.W.
  • JR
  • JR's Avatar
15 Sep 2023 18:52
#889429
Wierd.
I just downloaded a copy from Wookie58's link and opened it.
  • Cmelton
15 Sep 2023 20:11
#889431
It’s a retired police unit, so there’s wires everywhere. Neutral and oil stay on most of the time, all other marker, signal and driving lights alternate. I pulled the ignition switch, cleaned the contact points, greased the turn mechanism, soldered a wire back into place, put a new body and earth ground on. Presto, no improvement.
  • F64
  • F64's Avatar
  • 81-KZ440D2
15 Sep 2023 20:38
#889433
This should be a fun one.
There are probably hidden relays and switches within the harness.
1st step--identify exactly which lights or devices cut out.
You'll have to trace the positive wire of that dead light back through the harness to see where it goes.
That one light may lead to your entire issue..
81-KZ440-D2.
LIC, NY
