  • Page:
  • 1
KZ440 timing advancer 03 Aug 2023 17:37 #887916
  • Kzrider1980
  • Kzrider1980's Avatar Topic Author
  • Thank you received: 0
Pertaining to the timing advancer mechanism off a '83 KZ440D5 . . .
While cleaning and refurbishing this advancer (it was a solid block of rust) I mistakenly lost the "insert(s)" that fit into the notches on the weights (I hope my terminology is correct lol).
Is there a way to replace the lost inserts? What material are they? Phenolic? Metal?
Thanks in advance.
1980 Kz750E1
Last edit: by Kzrider1980.
KZ440 timing advancer 05 Aug 2023 07:03 #887970
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
From a post by loudhvx the little pads are rubber and when missing the timing can be off. you'd need to check the timing with a timing/strobe light. His comment was in regards to a 550 but I would assume it would be the same thing w any KZ timing advancer.
The following user(s) said Thank You: Kzrider1980
KZ440 timing advancer 05 Aug 2023 12:47 #887982
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1903
I would try to use 2 - 3 ring layer of shrink tube to mimic the rubber damper pads.
  • Page:
  • 1
