  • Page:
  • 1
Replacement headlight 10 Jul 2023 05:01 #887030
  • sf4t7
  • sf4t7's Avatar Topic Author
  • Thank you received: 258
Back in the day, they made the 7"sealed beam headlights in a version for autos and also a version marked "motorcycle".  The motorcycle version lens had a little different light pattern than the automotive one.  (I think it was a wider pattern to both sides, instead of wider on the right only for the automotive lamp).  Anyone know if they available in halogen, or are we stuck with the standard (automotive) H6024 7" units?
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replacement headlight 10 Jul 2023 05:36 #887033
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 621
NOS, 7" H4 Candlepower motorcycle headlights.
www.mfgsupply.com/motorcycle/light-bulbs...logen-headlamp.html+
If you look carefully at the pic, "MOTORCYCLE" can be seen cast into the lens across the bottom.  The lens facets are clearly (pun intended) asymmetrical for the motorcycle-correct beam pattern.
We bought a half-dozen to install on our Z1's in order to not put any more hours on the NLA OEM Stanley MC bulbs.  They arrived in new-condition mfg. packaging.   We're satisfied with these Candlepower units.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: by slmjim+Z1BEBE.
Replacement headlight 10 Jul 2023 06:21 #887038
  • sf4t7
Thanks,  that will work fine.  I guess the sealed beam motorcycle units are NLA.
Scotty
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replacement headlight 10 Jul 2023 09:00 #887055
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 310
On my 77' KZ 1000LTD I installed a 7" Stanley H4 motorcycle lense from an early 80's Honda CB 750. You can get them fairly cheap on fleabay.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Last edit: by Kelly E.
  • Page:
  • 1
