1983 750 LTD IC Ignitor mounting location
  • ericcer
  • ericcer's Avatar Topic Author
13 Jun 2023 05:56 - 13 Jun 2023 07:57
#885935
I recently purchased a 1983 Kawasaki 750 LTD Shaft and am trying to figure out where the IC Ignitor is supposed to mount. Seems like a bracket rusted out and was removed so that is why previous owner mounted this way. I cannot find any pictures in forum or Internet. Can someone provide one or some guidance?
Last edit: 13 Jun 2023 07:57 by Street Fighter LTD.
  • OKC_Kent
  • OKC_Kent's Avatar
Re: 1983 750 LTD IC Ignitor mounting location
13 Jun 2023 10:41
#885949
Maybe on the bottom of the battery tray?
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • Warren3200gt
  • Warren3200gt's Avatar
13 Jun 2023 11:07 - 13 Jun 2023 11:54
#885951
If its anything like the thou J series it mounts on the front bottom rh corner of the battery box so sits behind carb 4.
Z1000J2 somewhat modified!
Last edit: 13 Jun 2023 11:54 by Warren3200gt.
  • martin_csr
  • martin_csr's Avatar
13 Jun 2023 14:32 - 13 Jun 2023 14:34
#885959
The parts diagrams usually give clues as to how most stuff is mounted.  From the orientation of the bolts the ignition system diagram seems to indicate that the igniter is mounter under something, probably the battery box. EB photos can be helpful. the 750 Spectre has the same igniter & battery case components.
www.partzilla.com/catalog/kawasaki/motor...3/ltd-shaft-kz750-f1 << Ltd Shaft
www.partzilla.com/catalog/kawasaki/motor...982/spectre-kz750-n1 << Spectre
Last edit: 13 Jun 2023 14:34 by martin_csr.
  • Nessism
  • Nessism's Avatar
13 Jun 2023 16:20
#885967
On my 750E, the ignitor is mounted directly behind the fuse box, under the LH side cover.
  • ericcer
14 Jun 2023 08:34
#885985
Thanks for the help.I was aware of partzilla and other sources but just was not getting anything with clarity.
