1983 750 LTD IC Ignitor mounting location
- ericcer
13 Jun 2023 05:56 - 13 Jun 2023 07:57
I recently purchased a 1983 Kawasaki 750 LTD Shaft and am trying to figure out where the IC Ignitor is supposed to mount. Seems like a bracket rusted out and was removed so that is why previous owner mounted this way. I cannot find any pictures in forum or Internet. Can someone provide one or some guidance?
Last edit: 13 Jun 2023 07:57 by Street Fighter LTD.
- OKC_Kent
Re: 1983 750 LTD IC Ignitor mounting location
13 Jun 2023 10:41
Maybe on the bottom of the battery tray?
Cashion, OK
78 KZ650 B2 85,000+ miles
- Warren3200gt
13 Jun 2023 11:07 - 13 Jun 2023 11:54
If its anything like the thou J series it mounts on the front bottom rh corner of the battery box so sits behind carb 4.
Last edit: 13 Jun 2023 11:54 by Warren3200gt.
13 Jun 2023 14:32 - 13 Jun 2023 14:34
The parts diagrams usually give clues as to how most stuff is mounted. From the orientation of the bolts the ignition system diagram seems to indicate that the igniter is mounter under something, probably the battery box. EB photos can be helpful. the 750 Spectre has the same igniter & battery case components.
www.partzilla.com/catalog/kawasaki/motor...3/ltd-shaft-kz750-f1 << Ltd Shaft
www.partzilla.com/catalog/kawasaki/motor...982/spectre-kz750-n1 << Spectre
Last edit: 13 Jun 2023 14:34 by martin_csr.
13 Jun 2023 16:20
On my 750E, the ignitor is mounted directly behind the fuse box, under the LH side cover.
- ericcer
14 Jun 2023 08:34
Thanks for the help.I was aware of partzilla and other sources but just was not getting anything with clarity.
