  • Page:
  • 1
Acewell gauge 02 May 2023 14:09 #884128
  • lewisj
  • lewisj's Avatar Topic Author
  • Thank you received: 11
Hi guys, me again.  I am connecting an Acewell digital gauge to my 73 Z1.  The red wire in the schematic needs to be tapped into the “switch key”, which I assume to be the ignition.  The ignition has four wires, red, blue, brown and white.  What wire should I tap into?
Thanks in advance!,
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
ZR750S front forks
Delkevic exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
Acewell gauge 02 May 2023 14:45 #884133
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 390
In general on Kaws white is power from fuse to keyed switch.  Once the switch is turned on with key then the brown wire provides power to most of the systems on the bike other than lights witch are powered by the red and blue wiries.So I would splice into the brown wire.  But I am sure others will chime in.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Acewell gauge 02 May 2023 14:49 #884134
  • lewisj
Thanks gd4now, sounds logical!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
ZR750S front forks
Delkevic exhaust
Acewell gauge 02 May 2023 17:50 #884143
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1929
Yes, brown is the ignition key switched 12 Volt power wire!
Acewell gauge 02 May 2023 18:04 #884146
  • lewisj
Thanks Scorocco, should have the gauge and headlight wired in tomorrow.  Thanks for your help!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
ZR750S front forks
Delkevic exhaust
Acewell gauge 02 May 2023 18:57 #884151
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
The ACCURATE RPM reading/wiring will be the difficult part, don´t ask me about this horror senario!
Acewell gauge 02 May 2023 20:30 #884155
  • lewisj
We will see!  Instructions call for coiling the rpm wire around the plug wire or connecting directly to the coil.  Hope it works!
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
ZR750S front forks
Delkevic exhaust
Acewell gauge 02 May 2023 23:25 #884156
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1944
The coiling around the HT option may be less prone to the erratic readings that Scirocco experienced
  • Page:
  • 1
