  • Page:
  • 1
1976 Kawasaki KZ 400 without battery 26 Apr 2023 10:21 #883786
  • kdx200
  • kdx200's Avatar Topic Author
  • Thank you received: 0
Can A 1976 Kawasaki KZ 400 be started(kicked) and RUN without a battery?
1976 Kawasaki KZ 400 without battery 26 Apr 2023 13:21 #883793
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1890
No, the generator won't produce enough power at "kicking" speed to power the ignition
1976 Kawasaki KZ 400 without battery 04 May 2023 14:24 #884237
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Could installing condensator be a option?
Project:
1976 Kawasaki KZ 400 without battery 04 May 2023 17:42 #884244
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2089
A large capacitor might work, but a modern regulator and a LiFePo battery might be a better choice.
1976 Kawasaki KZ 400 without battery 04 May 2023 19:00 #884249
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 387
In theory I think that could work, but large capacitors can be dangerous. Back in the days of CRT-based televisions, people would get knocked on their backsides (or worse) by the capacitors inside the TV.
I think an ignition - even for a small bike - would need a noticeably larger capacitor than would be found in a TV, making the idea more risky.
Also I think the bike would basically need to start on the first kick every time for the concept to work. I'm not a double-e and might very well be wrong on the math. TexasKZ's idea is probably the way to go. :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
1976 Kawasaki KZ 400 without battery 04 May 2023 23:25 #884258
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
The stock generator is "regulated" by battery voltage (no battery means no regulation) so you would need a totally different generator set up (like a motocross bike or lawnmower) or you will fry the generator. Why do you want to run without a battery ? Also I believe the KZ400 has a "field coil" generator which requires a battery feed to the field coil to generate anything
Last edit: by Wookie58.
  • Page:
  • 1
