  • Page:
  • 1
  • 2
Possible to damp a fuel guage? 01 Dec 2022 10:23 #877392
  • Warren3200gt
  • Warren3200gt's Avatar Topic Author
  • Thank you received: 656
Thanks Guy, not to sure if you read that to the end but it didn't give a conclusive answer.
Op ended up buying a specific unit designed for the job. I've got several different size capacitors in the electro box and I'll have a play tomorrow. In parallel to the sender seems correct to me but electrickery is called electrickery for a reason.
Z1000J2 somewhat modified!
Possible to damp a fuel guage? 01 Dec 2022 11:17 #877394
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1788
Apologies, it was just a quick search as I am still working at the moment (silly season) the aim is to dampen the voltage fluctuations rather than change the voltage (which a resistor does) I am sure some of the electronics engineers on here can advise ref calculating a value for the capacitor and maybe take some of the guesswork out of it
Possible to damp a fuel guage? 01 Dec 2022 11:50 #877395
  • Warren3200gt
The sender seems to have a resistance of 100 ohm empty and 5 ohm full if it helps any calcs.
Last edit: by Warren3200gt.
Possible to damp a fuel guage? 02 Dec 2022 07:17 #877415
  • Warren3200gt
OK, just to round off the thread. After trying capacitors upto 1000uf in both series and parallel on the sender wires it made absolutely zero difference. So figuring to do what I was after achieving would require some serious circuitry and far beyond a simple fix my thoughts turned to a mechanical fix to the float/arm itself. Figuring if I could add some permanent friction between the arm and the sender body which would then reduce the immediately floppyness of the arm it would then result in what i was after. Once I decided to explore the mechanical possibilities the answer was obviously to put the arm under spring tension. The arm is still totally free to move but it takes a very little pressure or a slight jiggle, as if when ridding, to get it to move. I'll do a more elegant version once it's been tested on the road.
Possible to damp a fuel guage? 02 Dec 2022 09:26 #877417
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 133
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
The following user(s) said Thank You: Warren3200gt
Possible to damp a fuel guage? 02 Dec 2022 09:54 #877419
  • Warren3200gt
Thanks, that would certainly do what I was trying to achieve and as I suspected a far more complex circuit than I can be arsed to get involved in for what is no more than a niggle as outlined in my original post.
​​​​​​If it ever gets to the top of the annoyance list maybe I'll invest in one.
Possible to damp a fuel guage? 02 Dec 2022 10:10 #877420
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Just out of interest are these this erratic from new or is this down to a failure of an internal dampening circuit/mechanism in the gauge
Possible to damp a fuel guage? 02 Dec 2022 10:20 #877421
  • Warren3200gt
Don't know Guy, it's not exactly erratic just over sensitive to road gradients and throttle use. To give you an idea, from zero to full manually moving the arm the guage takes two seconds and vice versa so when fuel is sloshing around in the tank you can imagine the needle movement. The only way to get any real idea how much fuel you have is to be stationary on level ground.
  • Page:
  • 1
  • 2
