  • Page:
  • 1
Symptoms of a Failing Ignition Coil 11 Mar 2022 11:13 #863599
  • ShaneDude
  • ShaneDude's Avatar Topic Author
  • User is blocked
  • Thank you received: 13
I have a 1977 KZ750B Twin
Its been acting funny lately. First of all, the starter clutch gear is shot, so fixing that.
I am now noticing, after changing the spark plugs, that one plug is dark but not fouled, and the other is fine. Carbs are in good shape, but I notice the idle racing somewhat, but not often.
A friend said that coils on Twins go fail often because of vibration. For giggles, Im going to change the coil this weekend as I had a brand new spare.
Is poor running and one plug darker than the other, a symptom of failing coils?
The following user(s) said Thank You: KZmarcel
Symptoms of a Failing Ignition Coil 11 Mar 2022 13:04 #863601
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 658
Fouled how? Black carbon build up can be a sign of weak spark, over rich mixture or burning oil and/or low compression.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
Symptoms of a Failing Ignition Coil 12 Mar 2022 07:46 #863627
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
If it's an original/stock coil, then it could be that the windings are bad or the wires going into the coil have bad connections, especially the plug wires which might not be easy to fix since they're molded into the coils & not intended to be removed.
Symptoms of a Failing Ignition Coil 13 Mar 2022 06:36 #863692
  • ShaneDude
  • User is blocked
Thanks for responding. I changed the coil about 4 years ago.
Symptoms of a Failing Ignition Coil 13 Mar 2022 11:47 #863723
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1810
If the carbs are good the difference could be due to hardened manifold rubbers leaking air - you could try spraying WD40 etc round the rubbers with it idling and listen for a change in engine note
Symptoms of a Failing Ignition Coil 13 Mar 2022 11:48 #863724
  • ShaneDude
  • User is blocked
Was on it today. Its backfiring upon deceleration as well. I think its the coil. This happened 4 years ago
Symptoms of a Failing Ignition Coil 19 Aug 2023 09:43 #888492
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
  • Thank you received: 34
Just a thought, one big cause for backfiring upon deceleration is that of too small of pilots, doh just noticed user is blocked
1982 KZ1100D1
Symptoms of a Failing Ignition Coil 19 Aug 2023 16:52 #888509
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1033
It's easy to check a coil.  Measure your primary and secondary resistance.  If they are in spec then the coil is fine.  It may be your voltage to the coil is low.  Check and clean all of the contacts or maybe do the Wired George coil wiring change.
  • Page:
  • 1
