  • Page:
  • 1
KZ900 Turn Signals - What am I Missing? 23 Jun 2021 14:50 #850664
  • Erik Beeman
  • Erik Beeman's Avatar Topic Author
  • Thank you received: 2
This is probably a dumb question, but I have to ask it to be certain. See attached photo of my bike, which is a 76' KZ900. I'm not worried about the wiring/circuitry, but more about the physical parts I'm missing.
The bike has no blinkers. I'm searching for parts now and am having a hard time putting all the little pieces in my cart to make sure I've got everything I need. I've even looked at the parts diagram and I'm still kind of confused!
I know for sure I need:
- Turn signals (single wire? or double?)
- Stems
- What else?
So Z1parts sells a kit of 4 lights and stems.
z1parts.net/turn-signals-stems-z1-kz-h1-h2/
But I know there is some sort of rubber bushings, right?
This is complete for everything I would need for front, correct? z1parts.net/headlight-grommet-set-z1-kz-h1-h2-kh/
This is complete with everything I need for the rear, correct? www.z1enterprises.com/rr-turn-signal-gro...00-1000-650-400.html
Thanks for the help!
1976 KZ900
My dad bought brand new in '77 and as of 6/2021 has only 6,617miles
Last edit: by Erik Beeman.
KZ900 Turn Signals - What am I Missing? 23 Jun 2021 17:22 #850675
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
This will help with the rear. They are the ones with the ground wire.
www.partzilla.com/catalog/kawasaki/motor...z900-a4/turn-signals
Then look here for the front headlight bucket. Ad to the upper two shown on the above link.
www.partzilla.com/catalog/kawasaki/motor...6/kz900-a4/headlight
KZ900 Turn Signals - What am I Missing? 23 Jun 2021 17:33 #850676
  • Mikaw
  • Mikaw's Avatar
- Stems
- What else?
z1parts.net/turn-signals-stems-z1-kz-h1-h2/ This is wrong. The ‘76 900 uses single wire turn signals front and rear.
This is complete for everything I would need for front, correct? z1parts.net/headlight-grommet-set-z1-kz-h1-h2-kh/ Need to look at this closer, appears to have wrong grommets
This is complete with everything I need for the rear, correct? www.z1enterprises.com/rr-turn-signal-gro...00-1000-650-400.html This looks correct.
Last edit: by Mikaw.
KZ900 Turn Signals - What am I Missing? 23 Jun 2021 17:44 #850678
  • Mikaw
  • Mikaw's Avatar
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationFront;
  • 23076-005 x 2
  • 23066-016 x 2
  • 23066-015 x 2
  • 92075-128 x 2
  • 315B1000 x 2
  • stem x 2
  • housing and lens single wire x 2
Rear;
  • 92075-128 x 2
  • 92075-158 x 2
  • 92027-147 x 2
  • 92022-239 x 2
  • 26011-063 x 2
  • 461F1000 x 2
  • 315B1000 x 2
  • stem x 2
KZ900 Turn Signals - What am I Missing? 25 Jun 2021 09:24 #850736
  • Erik Beeman
Hi Mikaw, thanks for the response, I appreciate the help!
I'm pretty sure the light kit from Z1parts that I posted will work. There is a drop down menu to choose between single wire or double, and I chose the single wire.
I ordered the rear rubber bushing kit from Z1enterprise since it sounds like it was the complete kit. I haven't ordered the front kit yet. My bike currently has two plastic/rubber plugs on the sides of the headlight, I'm assuming those come out and that's where the front turn signals will go.
Thanks again!
1976 KZ900
  • Page:
  • 1
