  • Page:
  • 1
Trouble with turn signals- 1979 KZ750B 12 Jun 2021 04:16 #850048
  • brightboy68
  • brightboy68's Avatar Topic Author
  • Thank you received: 1
I bought a 79 KZ750B a week ago as my first motorcycle. It was missing turn signals when I got it, so I bought some off eBay and installed them (wiring is gray to gray, black/yellow to black/yellow for right, gray to green and black/yellow to black/yellow for left) as well as new bulbs for the indicator lights. Neither the front nor rear turn signals light up at all, and neither do the turn signal indicator lights.  What do I try next to get them to work?
-brightboy68 Indianapolis, IN
Trouble with turn signals- 1979 KZ750B 12 Jun 2021 06:27 #850052
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Is the flasher still in place. Is power getting in and out of the switch?
The following user(s) said Thank You: brightboy68
Trouble with turn signals- 1979 KZ750B 13 Jun 2021 08:16 #850110
  • brightboy68
The flasher may be missing because I can’t find it. Is this where it’s supposed to be?
Trouble with turn signals- 1979 KZ750B 13 Jun 2021 09:21 #850114
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 353
Those appear to be the wires that go to the flasher.
TexasKZ called it.
Orange and brown.
If you switch on your left or right turn signal and connect those two wires together, you will get a steady on light.
Put a flasher relay in and you should be good.
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Trouble with turn signals- 1979 KZ750B 14 Jun 2021 08:25 #850181
  • brightboy68
Can I put just any 2-pin 12 volt flasher in as long as it’s at or above the wattage listed in the wiring diagram?
Trouble with turn signals- 1979 KZ750B 14 Jun 2021 08:39 #850184
  • F64
  • F64's Avatar
  • 81-KZ440D2
Yeah, should be fine.
Unless you are running led turn signals. Then you may need a solid state flasher.
81-KZ440-D2.
LIC, NY
Trouble with turn signals- 1979 KZ750B 14 Jun 2021 08:54 #850185
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
I’ve had good luck with these.  Will work with both LED and incandescent
www.superbrightleds.com/moreinfo/flasher...nic-flasher/779/833/
  • Page:
  • 1
