Is all B7ES plugs the same?
- F64
- 81-KZ440D2
Re: Is all B7ES plugs the same?
26 Dec 2020 15:20 - 26 Dec 2020 19:30
for your reading pleasure
www.ngk.com/search/all?q=b7es
Yeah, you want NGK 1111 B7ES
NGK 2877 B7ES has a solid terminal
photo care of NGK.com
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 26 Dec 2020 19:30 by F64.
The following user(s) said Thank You: Mikaw, katit, tdogm6@yahoo.com
- katit
30 Dec 2020 14:12
Ok, this proves to be PITA Z1 does not carry those. I got 2 last plugs from local Autozone. Need 2 more and no local stores have them.
Seems like B7ES aka 1111 discontinued?
30 Dec 2020 17:14katit wrote: Ok, this proves to be PITA Z1 does not carry those. I got 2 last plugs from local Autozone. Need 2 more and no local stores have them.
As far as I know yes, but not actually discontinued but replaced. The B7ES is now a BR7ES. Resister plug now. I was able to order some through NAPA
30 Dec 2020 18:01 - 30 Dec 2020 18:02
After reading this I just ordered some ND W24ES-U plugs off ebay. It sucks that the old style removable top plugs are being discontinued.
Last edit: 30 Dec 2020 18:02 by Nessism.
30 Dec 2020 18:35
I've been using ND W22ES-U spark plugs in my KZ650 for the past 13 years and have found them to work better in my bike than the NGK plugs I previously used. Ed
- F64
- 81-KZ440D2
01 Jan 2021 00:54 - 01 Jan 2021 01:06
You can buy NGK caps meant for a terminal nut instead a terminal stud.
www.denniskirk.com/ngk/lb05ez-spark-plug...p20372.prd/20372.sku
www.ngk.com/plug-caps-ngk?pagenumber=2
picture-dennis kirk
picture-ngk
picture-dennis kirk
picture-ngk
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 01 Jan 2021 01:06 by F64.
The following user(s) said Thank You: Nessism, TexasKZ, Mikaw, tdogm6@yahoo.com
01 Jan 2021 09:02 - 01 Jan 2021 09:15F64 wrote: You can buy NGK caps meant for a terminal nut instead a terminal stud.
picture-dennis kirk
picture-ngk
Thank you. Very useful info. The problem with the plug is they are superseding the non-resistor plug to a resistor plug. The new BR7ES plug is still available in removable terminal nut but will not be usable with the existing resistor caps. I don’t understand the resistor concept but read that some resistance helps increase spark strength. But if you stack resistance then you diminish spark.
Last edit: 01 Jan 2021 09:15 by Mikaw.
- F64
- 81-KZ440D2
01 Jan 2021 10:01
Katit had originally purchased a solid terminal B7ES from ebay.
In that situation a different NGK plug cap would work.
The B7ES is still available but in a larger spark gap version (1.1mm vs .8mm).
You just have to tighten the gap and use a different spark plug cap as it's a solid terminal spark plug.
Part number NGK2311 (B7ES-11)
www.ngk.com/ngk-2311-b7es-11-nickel-spark-plug
table- www.ngk.com/search/partname?q=b7es
81-KZ440-D2.
LIC, NY
LIC, NY
01 Jan 2021 10:19
Correct to address the OP. We got off typic chasing plugs as the correction.
Thank you for finding the replacement non-resistor plug. Why or what is the reasoning to go to Nickle? I also see the 2311 is a solid nut. So to continue to use the NGK we would have to swap in new caps.
- katit
01 Jan 2021 10:31
Too late with info. Already found correct plugs and 5k cups. There is still NOS plugs on ebay
- F64
- 81-KZ440D2
01 Jan 2021 12:08
No worries katit.
I somewhat enjoy the research and seeing what solutions are available.
Mikaw,
Yeah, essentially you would swap caps. They twist on so it's not too much trouble.
Below is NGK's explanation on different metals they use.
Mikaw,
81-KZ440-D2.
LIC, NY
LIC, NY
The following user(s) said Thank You: katit
