  • Page:
  • 1
need help with wiring up a relay 14 May 2006 13:55 #47201
  • 94yj
  • 94yj's Avatar Topic Author
  • Thank you received: 0
does anyone have a wiring diag for how to wire up a relay ie what pins are power /load and gnd/and excite terminal i am having to build my own wiring harness and i am going to wire back to factory plus a protection relay in the main power circuit
thanks
need help with wiring up a relay 14 May 2006 14:41 #47212
  • jbw7300
  • jbw7300's Avatar
  • you can't ride if your fried
most relays have the diagram on the side of it, if you post a pic of the relay i could give you an idea of what to do
84 kz 700 a1 sports
need help with wiring up a relay 14 May 2006 14:49 #47214
  • 94yj
the ones i have seen have no diag just numbers on the side where the wires plug up
need help with wiring up a relay 14 May 2006 15:48 #47223
  • jbw7300
  • jbw7300's Avatar
well then if you don't have a diagram you'll need to pull the cover off of the relay and see where the tangs go to, inside you'll see a energizing coil one tang to each side these would be power and ground the other two are the switched circuit. unless you have a five wire relay then i would suggest you go to the local parts store and get yourself a 4 wire relay.
84 kz 700 a1 sports
need help with wiring up a relay 14 May 2006 16:32 #47235
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Here's a dia. for the coil powering mod:
Post edited by: rstnick, at: 2006/05/14 19:33
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
need help with wiring up a relay 14 May 2006 16:47 #47238
  • jbw7300
  • jbw7300's Avatar
there you go!
84 kz 700 a1 sports
need help with wiring up a relay 15 May 2006 06:34 #47360
  • 94yj
thanks rstnick that is the one i needed
need help with wiring up a relay 16 May 2006 06:44 #47680
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
The person who did that drawing should have put yellow/red for the coil wires and subsequently, the "excite" wire. I always call that a trigger wire the the term "EXCITE" sounds soooooo much more... well exciting!
  • Page:
  • 1
