  • Page:
  • 1
need feed back on this daigram please !!! 19 Apr 2006 21:19 #40999
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
  • Thank you received: 1
i got the bike running but it was to dark for a test drive!!! i was messing with that wire digarm (displayed on page) and thought this may work. need feed back on this diagrm please!!! if this is worng or i need more/less of any thing let me know.
just want to be able to ride at night, as well as have a brake light to. (and be safe)!
Post edited by: steveo_4192003, at: 2006/04/20 00:20
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
need feed back on this daigram please !!! 19 Apr 2006 22:29 #41018
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Looks good to me. Make sure you run all of the grounds using wire to the bolt that has the battery ground. Frame doesn't work well as a ground when it gets most and corroded.
I would suggest the power to the rear-brake-switch should come before the tail-light-fuse. That way it won't confuse you and act goofy if the tail light fuse blows.
The only real problem is the label... it is no longer "bare minimum!" :)
need feed back on this daigram please !!! 19 Apr 2006 22:50 #41023
  • steveo_4192003
  • 77kz650b-1
thanks for the feed back !!!
i will fix the lable lol!
nice to have someone who knows what they are doing, just to check over newbies plans, and give them GREAT advice thanks agian!!!!B)
need feed back on this daigram please !!! 19 Apr 2006 22:59 #41025
  • steveo_4192003
  • 77kz650b-1
FIXED IT IS THIS RIGHT?
need feed back on this daigram please !!! 20 Apr 2006 00:57 #41033
  • loudhvx
  • loudhvx's Avatar
That's it!
need feed back on this daigram please !!! 20 Apr 2006 01:36 #41038
  • btchalice
  • btchalice's Avatar
  • Thank you received: 7
wheres the ground for the taillight?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
need feed back on this daigram please !!! 20 Apr 2006 07:36 #41088
  • loudhvx
  • loudhvx's Avatar
That's the yellow/black wire coming out the top.
  • Page:
  • 1
