  • Page:
  • 1
Strange turn signal behavior 19 Apr 2006 20:31 #40982
  • rtrider73
  • rtrider73's Avatar Topic Author
  • Thank you received: 0
Last evening all worked well.
Today I ran the bike around the block upon return I noted that my turn signals would not work. Rear lights stay dark, front signals stay on as they should as running lights. Hazards will not work, but I noted that the left turn signal indicator would light when I did try to use the hazards. All bulbs appear to be good upon inspection, I swapped out the flasher relay just in case with no change in the problem. I did have the bike on the charger this morning for a few hours otherwise no other work was performed on the bike. Methinks I have a gremlin at work in the garage. Any thoughts?
Thanks,
Rob
. 19 Apr 2006 21:15 #40995
  • JMKZHI
  • JMKZHI's Avatar
  • Thank you received: 48
del
Last edit: by JMKZHI.
Strange turn signal behavior 20 Apr 2006 05:08 #41048
  • rtrider73
Sorry Folks!
Posted this late last night and forgot to include the most basic information.
My 1979 KZ650b is where this problem exists.
~R
Strange turn signal behavior 20 Apr 2006 06:55 #41075
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
Would these be stock or aftermarket signals?
Strange turn signal behavior 20 Apr 2006 07:45 #41090
  • Sputnic81
  • Sputnic81's Avatar
I had a similar prblem with my KZ 440. Turned out to be corroded ground wires. Don't know if you have checked that but it is a thought.
(POST MORTEM) Re:Strange turn signal behavior 21 Apr 2006 17:02 #41522
  • rtrider73
Well here's an update.
The gremlins seem to have departed for greener pastures at least for the time being. Went for a ride yesterday and all worked just dandy.
I tend to agree with Sputnic81 in that this smells like a bad ground. Now I just have to find it. Thanks to all who replied.
BTW these are stock signals.
Rob
  • Page:
  • 1
