  • Page:
  • 1
Too long charging damage a battery? 25 Mar 2006 16:26 #34258
  • gas
  • gas's Avatar Topic Author
  • Thank you received: 0
I couldn't find anything relevant to my question in the archives. New battery last spring. I added the distilled water/acid myself, gave it a complete charge and rode all year no prob. This winter I have been giving it about 10 hours at a 2 amp trickle charge (2/10/50 amp charger)every month to 6 weeks. The other day I forgot about unplugging it and the battery took the 2 amp charge for about 24-30 hours. The battery was/is not in the bike and now reads 12.23-12.25 V on the 12v Battery test setting on my multimeter. What are the odds that I did some damage?
Too long charging damage a battery? 25 Mar 2006 16:35 #34261
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Check the water level. If it's still up around normal, your probably ok.
Too long charging damage a battery? 25 Mar 2006 16:35 #34262
  • fixer5000
  • fixer5000's Avatar
  • Thank you received: 5
probably none...i get mine to boil once in a while in the off season its actually good for it....no worries...steve
1978 kz650b pretty much stock
massachusetts
Too long charging damage a battery? 25 Mar 2006 16:40 #34263
  • oldcoldankles
  • oldcoldankles's Avatar
  • Thank you received: 3
I do the same as you Chris, and my battery is now into it's 3rd year of life. I have one truck with a solar trickle charger on it 24/7 and the original batteries lasted 8 years before requiring replacement. My guess is your charger tapers off to lower amps as the voltage climbs and your battery should be fine:)
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
Too long charging damage a battery? 25 Mar 2006 17:14 #34271
  • gas
Cool. Thanks all.:)
  • Page:
  • 1
