  • Page:
  • 1
Busted My New Electronic Ignition 11 Feb 2006 14:50 #23172
  • ltdrider
  • ltdrider's Avatar Topic Author
  • Thank you received: 17
I installed the new Dyna S today. Installation went smooth as silk, and I was getting ready to set the timing.
But when I put a wrench on the shaft nut and turned the engine, my wrench (open end..Doh!) sheared off one of the plastic covers on the points plate. Guess I should have used a socket and extension.
$120.00 shot to hell.
Here's the damage:
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Busted My New Electronic Ignition 11 Feb 2006 15:04 #23177
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
That S%#CKS! Can it be repaired?
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Busted My New Electronic Ignition 11 Feb 2006 16:15 #23192
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
  • Thank you received: 35
From photo it looks like it sheared where the plastic is glued to the metal. If this is the case, send email or call the manufacturer, tell 'em what you did, ask 'em what kind of cement to use to fix it.
If you're hell bent on throwing it in the trash, let me take care of that for you ;-)
-Duck
Busted My New Electronic Ignition 11 Feb 2006 16:28 #23199
  • ltdrider
I think the cover holds some of the elctronics, and it is soldered to the circuit board underneath. It would take a better electronics guy than me to fix it.
Duck:
I'll check it out when I remove it from the bike. If it looks too far gone for me, I'll send it to you. I'll send you a PM and let you know.
Greensboro, NC
Busted My New Electronic Ignition 11 Feb 2006 16:42 #23206
  • Duck
  • Duck's Avatar
That piece thats held on with what look like cap screws or rivets, kind of mottled cyan on my ancient display, is a circuit board!
It looks like an Aluminum plate in the photo.
-Duck
. 11 Feb 2006 19:09 #23242
  • JMKZHI
  • JMKZHI's Avatar
  • Thank you received: 48
del
Last edit: by JMKZHI.
Busted My New Electronic Ignition 11 Feb 2006 19:38 #23251
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
JMKZHI wrote:
Tell 'em what ya did - maybe they'll send you a replacement. It wouldn't hurt to try. hee.
JMK.
ltdrider you hamfisted bodger you, what did you do???? j/k man :P :P
That's gotta hurt, ego and wallet. Anyhow, I have spoke with Dyna via email a bit and they seem like good folks. See if they might cut you some kinda deal or repair even?
Don't fret about it much though, we've all pulled our tricks - betcha that don't happen twice! ;)
Get right or get left! <*{{{><
Busted My New Electronic Ignition 11 Feb 2006 19:48 #23255
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
That thing might still work for someone with a 750 twin or maybe even a 400 twin.
Busted My New Electronic Ignition 11 Feb 2006 21:09 #23275
  • tfh903
  • tfh903's Avatar
  • Thank you received: 8
If Dyna won't take care of you, I'd try some epoxy glue, if you trash it, and if Duck doesn,t get it I call seconds. That's the same side I fried when the regulater crapped.
Busted My New Electronic Ignition 12 Feb 2006 17:29 #23422
  • SquatchAirClutchSystems
  • SquatchAirClutchSystems's Avatar
  • Thank you received: 0
If you run into a dead end...let me know...i think i have a couple that are not on plates (ie..someone removed them from the main plate) I 'll send one to you. I'm not sure if they are bad or not..
Mike
Busted My New Electronic Ignition 27 Feb 2006 19:46 #26934
  • KL250
  • KL250's Avatar
Or me with a 250 single...
Busted My New Electronic Ignition 28 Feb 2006 03:23 #27008
  • indykaw77
  • indykaw77's Avatar
Might as well give'um a shout or call.....whats the worst they can say, No? Ya never know......
Kawasaki Motorcycles...because cars lean th wrong way!
  • Page:
  • 1
