Engine dies when throttle opened quickly
- Andyp62
08 Feb 2024 10:58
Hi all
i have sorted some problems with the help of you guys here, I am at the stage now where my KZ 650B2 1978 will start easily now and seems to run ok but if you snap the throttle back quickly it hesitates and dies, it has a new Dyna ignition and coils and the timing is spot on at idle and full advance, compression is 155 on all 4 cylinders so I think it must be carburation, it has stock air box and jets, needle is on middle position but the plugs are quite black
thanks
thanks
1978 Z650 B2, US import to the UK
- !Seymore
- Ride on...
Re: Engine dies when throttle opened quickly
08 Feb 2024 11:05 - 08 Feb 2024 11:06
How many turns out on the air screws?
You're running really rich...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 08 Feb 2024 11:06 by !Seymore.
- Warren3200gt
08 Feb 2024 12:28 - 08 Feb 2024 12:30Totally normal for a normal carburated engine.Hi all
thanks
If you wack open the throttle very very quickly, the available air flow through the slide is big. As its big there is little vacuum to draw fuel through the pilot jets.
Result is loads of air with very little fuel ultra lean mixture and there is no combustion to keep the engine running.
This situation will only apply if in neutral and not evident If the bike is being ridden then the engine will continue being turned over via forward motion through the gearbox and everything will catch up with itself.
This is one of the reasons most modern vehicles use fuel injection as both fuel and air can be increased simultaneously.
Get your fuel mixture correct and open the throttle as though you were riding and it won't cut out.
Last edit: 08 Feb 2024 12:30 by Warren3200gt.
The following user(s) said Thank You: howardhb, Andyp62
- Andyp62
09 Feb 2024 01:06
I have had the air screw from one turn to 3 out with little effect on tickover
- Andyp62
09 Feb 2024 01:09
Thanks guys
09 Feb 2024 07:27This makes me suspect that the carbs are not clean. The pilot mixture passageways are really small and can clog easily. If the air screw passageways are clogged, the idle mixture will be very rich.I have had the air screw from one turn to 3 out with little effect on tickover
The following user(s) said Thank You: linuxrob, Andyp62
- gd4now
- Denco where did you go?
09 Feb 2024 09:12
I know you have been through several things with your machine,, but do not recall all of them off the top of my head and have not gone back and looked at your other posts. But I might ask if the choke/enricher is leaking?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- !Seymore
- Ride on...
09 Feb 2024 13:33OK Andy... I suspect a good carb cleaning is in order. Put the rack and go to town...Thanks guys
It's too bad that the .INFO site is no longer, I had a great write-up there on carb cleaning...
C.
The following user(s) said Thank You: Andyp62
- Andyp62
11 Feb 2024 03:57
Not sure about the choke leaking but I will check it out
- Injected
12 Feb 2024 11:33 - 12 Feb 2024 11:40The rubber seals go hard, that lets extra gas into the throats at all speeds, black spark plugs are a clue. This is typical on +45 year old carbs.Not sure about the choke leaking but I will check it out
Small circuits in the carb bodies (pilot jets) can also close up with gas tarnish over time especially if they were stored without flushing correctly.
You can spray all the passages in the carbs without splitting them, just remove from the rubbers and hang rack off the side of the engine by the cables (support with bungee) Take the bowls off then spray with carb cleaner, remove all jets and spray with carb cleaner, blow out with compressed air, reassemble.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 12 Feb 2024 11:40 by Injected. Reason: info
- Andyp62
13 Feb 2024 07:51
Thanks I will give that a try
- Injected
13 Feb 2024 08:14Just noticed your in the UK.Thanks I will give that a try
You should get a hold of Zed1015 as he rebuilds choke plunger seals and is in the UK.
He is also on the Z1OC forum and the Z650 forum both run out of the UK so its not that hard to track him down.
