  • Page:
  • 1
Mikuni BS34 Carburetors~Velocity Stacks? 25 Jan 2024 18:31 #894424
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Thank you received: 636
What might be the pros and cons of using velocity stacks with BS34 carburetors?
1982 KZ1100-A2
Mikuni BS34 Carburetors~Velocity Stacks? 25 Jan 2024 18:39 #894425
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Unfiltered air is unhealthy for motor
Oil dirtier faster
scuffed cylinder walls
The only place for a motor without any filters is on a race track or Boat
The following user(s) said Thank You: Nessism, daveo, howardhb, Wookie58
Mikuni BS34 Carburetors~Velocity Stacks? 25 Jan 2024 22:53 #894430
  • daveo
  • Premium Member
Oil dirtier faster
I use RamAir MS-006 filters with stacks on my RS34's.  BS34's have identical center spacing measurements, though front-back they are longer.
photos.app.goo.gl/nrM19WHFqYd285R79
1982 KZ1100-A2
Last edit: by daveo.
Mikuni BS34 Carburetors~Velocity Stacks? 26 Jan 2024 14:31 #894478
  • daveo
  • Premium Member
Oil dirtier faster
I use RamAir MS-006 filters with stacks on my RS34's.  BS34's have identical center spacing measurements, though front-back they are 10mm longer.
The idea of using POD FILTERS with BS34 CV carbs is discouraged.
PODS can hinder proper CV carburetor function, and drive sane people crazy with wild jet chases...
Do VELOCITY STACKS minimize detrimental cross-wind effects associated with PODS, as they direct air flow straight into the carburetor opening?
MS-006 filters, Made in the UK
1982 KZ1100-A2
Mikuni BS34 Carburetors~Velocity Stacks? 26 Jan 2024 15:17 #894479
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1808
You could always do something similar to the mods I have made to the stock airbox, this gives the extra flow without the downside of pods (K&N panel is for a 3.7ltr V6 Infinity) you would have more room to play with not having the monoshock
The following user(s) said Thank You: daveo, howardhb
Mikuni BS34 Carburetors~Velocity Stacks? 26 Jan 2024 16:37 #894480
  • daveo
  • Premium Member
WOW Wookie58, that is a masterpiece of craftsmanship and incredible idea...Dude!
My air box appears somewhat stock too...
It was gutted and the front was widened to fit the 3" long Mikuni trumpets (with filters) partly inside, in lieu of having to utilize rubber air box boots.
Those boots were a restrictive pita when I needed access to the RS carbs.  They got increasingly stiff from age and constant internal exposure to ethanol in our fuel.
Mikuni stacks will never become soft , and are easy to remove through the snorkel lid opening beneath the seat.
Like to see pics of your air box mounted in the frame.
1982 KZ1100-A2
Mikuni BS34 Carburetors~Velocity Stacks? 27 Jan 2024 00:56 #894484
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Mikuni BS34 Carburetors~Velocity Stacks? 27 Jan 2024 09:27 #894489
  • daveo
  • Premium Member
Wookie, your machine is like beautiful sculpture that naturally demands attention.
1982 KZ1100-A2
  • Page:
  • 1
