Carb float bowl gaskets 23 Jan 2024 10:10 #894351
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 437
Ok  New challenge!
I live at the bottom of Africa!
USPS have (recently) successfully delivered parts (Speedo / Tacho) from Hawaii, but it wasn't cheap, $65 for a half a shoe-box, 1½  pound contents, and it took 6 weeks!
So, I will first see if I can find one at my local bike breaker, The Bike Hospital, this weekend.
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
Last edit: by howardhb.
Carb float bowl gaskets 23 Jan 2024 10:11 #894352
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 307
My hazard switch is intact but the same pink color as those.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Carb float bowl gaskets 23 Jan 2024 10:32 #894354
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 260
Same with mine Kelly, I was gonna try to paint it but I was afraid I would make it look worse I did try to use a heat gun to bring out the pigment but that didn't work.
Carb float bowl gaskets 23 Jan 2024 11:31 #894358
  • asphalt900
  • asphalt900's Avatar Topic Author
  • Thank you received: 167
See, there ya go. Have no problem shipping examples to Your location if You can't source those bits local. I ship, and have been for years doing international. Probably 90percent of the stuff went to other places beyound the US. Let me know what You find out. AND, because i have boxes of these switchblocks, need any?
Carb float bowl gaskets 23 Jan 2024 11:32 #894359
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 657
Used it dye nylon props and plastic spinners on RC models back in the day. Remember it seemed to work OK. That was mostly red or black dye on white base material so red on faded red should work great. Used it like a stain. Available in all colours.
From their website
In a medium saucepan used exclusively for crafts or dyeing pour in liquid dye and bring to a rolling boil. Reduce to a simmer and submerge plastic items into the dye bath with a slotted spoon, stirring constantly and removing items regularly to check on their coloration."
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
Carb float bowl gaskets 23 Jan 2024 11:45 #894361
  • howardhb
  • howardhb's Avatar
  • God, I trust
These were very "pink" (oxidised) to start with.
A mixture of Wintergreen oil and Olive oil, applied multiple times (more than 10) brought the colour back nicely!
Carb float bowl gaskets 24 Jan 2024 05:34 #894369
  • howardhb
  • howardhb's Avatar
  • God, I trust
I've drawn the button according to what I see in your pictures, and all dimensions are ASSUMED, for now.
H.
Carb float bowl gaskets 24 Jan 2024 06:31 #894372
  • asphalt900
WOW, You have tech i wouldn't have a clue how to use!! Here's the old fashioned way. Note that the plate with the "Hazard" feature isn't perfectly perpendicular, slight angle. Other than that i believe You have it rangled!!  Here's a finished "thru bar harness" version for a 1978 LTD 1000 for completeness.
Carb float bowl gaskets 24 Jan 2024 06:38 #894373
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1863
I’ll buy at lease 6 if this becomes a real thing
Carb float bowl gaskets 24 Jan 2024 07:06 #894376
  • howardhb
  • howardhb's Avatar
  • God, I trust
Thanks for those dimensions, this gives me an idea of scale...
Could you measure and correct the dimensions I've circled in green?
It would be helpful if you would correct all my dimensions...
I need to print a few "prototypes" to identify the best way to position the model in the printer for best result.
H.
Carb float bowl gaskets 24 Jan 2024 08:49 #894381
  • asphalt900
Does this give You any insight? Kinda hard to measure from the curvature or centerline but.. What You relly need is a "hold-in-hand template"! Seems the 3/32" pin is a close approximation of the latching feature which solves that (1.5 you have pictured). So crude measuring shows that the reduced latching area is approx 1.85mm at the leading edge before the plastic reduces and/or Your 1.20 mentioned section. The flat (5 shown) is about 7.10mm. Help??
Carb float bowl gaskets 24 Jan 2024 08:52 #894382
  • asphalt900
Whoops last pic wasn't a good representation, hows this.
