  • Page:
  • 1
vacuum gauge adaptor hack? 18 Aug 2023 21:07 #888471
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
  • Thank you received: 36
Do I need to buy 2 special Kawasaki adaptors at 30 to 50 bucks total and wait a week to get them just so I can connect vacuum gauges for carb synch? Or can I rig something else up at the hardware store? The Harbor Freight gauges I would use (yeah but they're better than nothing) don't have metric adaptors
vacuum gauge adaptor hack? 18 Aug 2023 21:36 #888473
  • ckahleer
  • ckahleer's Avatar
  • Thank you received: 138
To make an adapter, find a bolt that threads tnto the hole. Cut the bolt so you have a piece that there a few threads on one end and .5" of smooth on the other. drill a small hole through it.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
vacuum gauge adaptor hack? 19 Aug 2023 06:30 #888479
  • 82KZ305Belt
 Are you thinking the hose is big enough to fit over the smooth end?
vacuum gauge adaptor hack? 19 Aug 2023 06:58 #888481
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
You can make the smooth end any diameter you need. Could you buy adaptors from another gauge company?
vacuum gauge adaptor hack? 19 Aug 2023 08:15 #888487
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Maybe you could get some plastic vacuum fittings from the auto parts store or on EB.
EB search = 6mm vacuum fitting .... chose 6mm at random. I have no idea what size you need.
EB search = 6mm Hose Pipe Connector
Last edit: by martin_csr.
vacuum gauge adaptor hack? 19 Aug 2023 08:21 #888488
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2680
An example of homemade adaptors...
vacuum gauge adaptor hack? 19 Aug 2023 13:14 #888501
  • ckahleer
  • ckahleer's Avatar
Looking at the homemade adaptors pics Nessism posted, It looks like the brass tubes are about the same diameter as the bolt.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
vacuum gauge adaptor hack? 19 Aug 2023 14:12 #888502
  • 82KZ305Belt
Are the tubes epoxied or cemented onto the bolts? Heading to the hardware store now...
  • Page:
  • 1
