  • Page:
  • 1
Jetting after a rebuild 29 Jul 2023 13:54 #887710
  • kzken750
  • kzken750's Avatar Topic Author
  • Thank you received: 0
I have just rebuilt my kz750 with a wiseco piston kit bringing it to 810cc. The bike stock has a #125 secondary jet. Before the rebuild and with the 4 into 1 Yoshimura pipe I had boosted the jet to #130. With the larger pistons from the rebuild I went up again to #142.5. The bike seems to be starving for gas and the spark plugs are whiteish. How far up should I go with the jet size?
thanks
Jetting after a rebuild 29 Jul 2023 15:38 #887713
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2680
I don't know what to say about jetting other than Dynojet.
That bike sure looks nice!  Love how tight the pipe tucks up tight to the sump.
The following user(s) said Thank You: kzken750
Jetting after a rebuild 29 Jul 2023 15:51 #887715
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1900
Don´t forget to went up with the pilot jets.
Jetting after a rebuild 31 Jul 2023 06:09 #887747
  • Beaner242
  • Beaner242's Avatar
  • Thank you received: 16
Yes. When are you checking the plugs?  You may be jetting the main when you need bigger pilots.
1982 KZ1000K LTD Chopper
Jetting after a rebuild 31 Jul 2023 11:09 #887749
  • Nessism
  • Nessism's Avatar
The Keihin CV34 carbs, as used on this bike, have both a primary and secondary main jet.
The Dynojet kit comes with new secondary main jets and new needles.  They don't mess with the primary main jet, or the pilots.
www.dynojet.com/amfile/file/download/file/558/product/3255/
Last edit: by Nessism.
Jetting after a rebuild 03 Aug 2023 06:08 #887890
  • kzken750
bigger pilot jets are on the way. Also going up to #150 on the mains. I got advice at first that I did not need bigger pilot jets. I hope this will do it. thanks
  • Page:
  • 1
